Cant adjust my rear end passenger side axle is tighter than drivers side. Looks as if someone left out some parts when they changed bearnings. Just a thought why they wont tighten up. Any help Thanks.
The only adjustment for either side is on the passenger side! And yes, listen to fishy68, he knows his rear end stuff! No drivers adjustment may certainly be caused by no thrust buttons, which put pressure on the drivers side axle, forcing it against the tapered bearing race during adjustment! Without them, no drivers side adjustment at all!! Geof
More information would help.
1) Is this a Sure Grip
2) Stock taper style axle bearings
3) Green style sealed roller bearings
4)Stock or after market axles
5) Pictures of everything always helps
