Thank you in advance for any and all help. Well I was putting 8 3/4 clutch pack back together and when I was bolting the 2 half’s together one of the case bolts broke. So I need to know if anyone knows where I can get these bolts.
These are left hand threaded bolts. I don’t know anyone around where I live who would carry them. I will check at Ace hardware on Monday
click on the link McMaster-Carr Not sure on the length you will have to check that, its been a while sense I had one apart
Nothing that has anything old. Everything here got crushed after Hurricane Katerina. I’m lucky to find any Hong for my 2000 Dakota.
I was hoping to find a pack and not spend all day searching the web. I will call them on Monday. thanks again
i believe ARP has them -- 3/8 -24 FINE left hand thread -- McMaster - Carr only has left hand 3/8 - 16 coarse thread -- if you cannot locate a bolt ( good luck ) and do not want to spend what ARP wants for them -- take a spare ring gear bolt cut off the head and get a regular grade 8 bolt the right length and cut and weld the two together for the correct length,, if welded properly it will take the torque required.
