8 3/4 Wheel Studs
Discussion in 'Suspension, Steering and Chassis' started by limegreen70, Aug 4, 2018.
  1. limegreen70
    limegreen70 Pokorny Enterprise's
    1,353
    189
    Apr 27, 2014
    Milton PA
    View My Photos
    Local Time:
    5:45 AM
    I need to put some new wheel studs on my rear end (Small bolt) but the ones i have seem to not fit to tight. I want to get better ones, what is the stock Knurl diameter for Abody wheel studs?
  2. bbrroowwnn
    bbrroowwnn never re member FABO Gold Member
    10,745
    492
    Nov 27, 2010
    Drums, PA
    View My Photos
    Local Time:
    6:45 AM
    I bought these...when I replaced mine and they worked great....
    Wheel Lug Stud Rear/Front Dorman 610-186 | eBay
    .472 knurl diameter but you must check your own with caliper to see what they are.....who knows if they were ever changed
    • Thanks! Thanks! x 1
    • halfafish
      halfafish 66 Valiant, hot-rod in training FABO Gold Member
      436
      246
      Aug 14, 2016
      SW Washington
      Local Time:
      3:45 AM
      I am installing a 8-3/4 in my Valiant, SBP axles. I pulled the LH thread ones to replace them with RH studs, as my front discs are all RH studs and I couldn't think of anything dumber than having three RH positions and one LH position. My used studs measure right about .467 or so, and the new ones (found them at Rock Auto) are about .474 or so.
      • limegreen70
        1,353
        189
        Apr 27, 2014
        Milton PA
        View My Photos
        Local Time:
        5:45 AM
        If knurl size is to big will they not fit in the stock holes?
      • bbrroowwnn
        10,745
        492
        Nov 27, 2010
        Drums, PA
        View My Photos
        Local Time:
        6:45 AM
        you want a couple thousands bigger than holes so they fit tight and don't spin.....I drew mine in with impact wrench, lug nuts and washers until they bottomed out on the back side...
      • bbrroowwnn
        10,745
        492
        Nov 27, 2010
        Drums, PA
        View My Photos
        Local Time:
        6:45 AM
        oh and they also come in different lengths.....so the longest stud you can get in without pulling the axles out is about 1-1/2 inches......any longer you have to pull axles to install
      • limegreen70
        1,353
        189
        Apr 27, 2014
        Milton PA
        View My Photos
        Local Time:
        5:45 AM
        I understand that part but I see some are like .570 knurl size and some might be .480 or so. Didn't know if it could be to big.
      • bbrroowwnn
        10,745
        492
        Nov 27, 2010
        Drums, PA
        View My Photos
        Local Time:
        6:45 AM
        well that is .090 difference which is roughly 3/32 bigger than the other one....I personally would not go more than .020 bigger than the hole
