[SOLD] 8.8 rearend 4.10 gear/posi for moved in springs on abody
1bad360duster
Rating - 0%
0   0   0
8.8 rear out of explorer. Was in a duster with springs moved in. 31 spline stock axles with thicker tubes. tubes have been welded to housing. perches fully boxed/welded. Had ford motorsport posi installed with carbon clutches and aluminum cap support cover. 4.10 gears. Disc brakes in good shape $850 obo located lower NY
Common mod is to cut a few inches off the left (longer) side, weld back up and insert a spare passenger axle. Narrows the rear a few inches and centers the pumpkin. I'm wanting to put one in my 55 chevy as I'm sick of the b.s. with stock rear.
Ah yes I’ve heard of that, but this rear worked well for stock abody wheel offsets so I left it.
Was it narrowed by using a passenger's side axle on the driver's side or is it a stock width Explorer rear. I really cannot tell from the pictures. Thanks
it is stock width explorer, which is very close to stock width a body if I'm correct. Let me know if you have any other questions. thanks
bump, this will make a great street strip rear for someone. got new rear so dont have room to keep this hanging around. make a reasonable offer
