1. Snoman
    Snoman Active Member
    25
    0
    Jul 16, 2011
    northern wi
    Local Time:
    5:37 AM
    Hey i just put a rebuild kit in my b body 833 trans and it all went well, i installed new syncro rings, bearings, sliders, keys, now I have one question, it seem to up shift ok, but when i down shift into second i get a little grind when it goes into 2nd gear. It only does it when i pull pretty hard on the shifter, if i don't pull hard it wont go in at all until slower speeds. What do you guys think? Thanks
  2. dano
    dano Evil Handy Man FABO Gold Member
    2,345
    379
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    3:37 AM
    Is your shifter mechanism new too?
  3. Snoman
    25
    0
    Jul 16, 2011
    northern wi
    Local Time:
    5:37 AM
    no it is the old shifter mech. seem to be in pretty good shape, I forgot to add i am using synthetic atf trans oil too.
  4. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,473
    1303
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    5:37 AM
    ............THERES UR PROBLEM....DO NOT USE SYNTHETIC anything in an 833.......kim.......
  5. Snoman
    25
    0
    Jul 16, 2011
    northern wi
    Local Time:
    5:37 AM
    ok i will swap out the fluid and give it a try
  6. chignikred
    chignikred Well-Known Member
    402
    16
    Apr 12, 2009
    WA
    Local Time:
    3:37 AM
    this usually is a stop ring issue. you did put in new?
  7. omahamoparguy
    omahamoparguy Well-Known Member
    762
    20
    Feb 19, 2010
    Local Time:
    4:37 AM
    yes, depending of what type of stop rings and synchros you have that tells you what type of fluid to use. Old style, you use old 75/90 gear oil. this makes the synchro's slow down fast like when you are downshifting.
  8. Snoman
    25
    0
    Jul 16, 2011
    northern wi
    Local Time:
    5:37 AM
    I put in a rebuild kit from brewers, I guess i am not sure what you mean by stop rings?, I put in new sliders, new sycros, new keys, bearing. I didn't get a chance to change the fluid yet. hopefully soon what fluid should i use. Thanks for the help
  9. mjs69gts
    mjs69gts Well-Known Member
    847
    14
    Jan 7, 2011
    madison wi
    Local Time:
    5:37 AM
    use 75w90 gear lube
  10. Snoman
    25
    0
    Jul 16, 2011
    northern wi
    Local Time:
    5:37 AM
    any specific kind of 75 90, I thought someone said to us a CL 4 rated gear lube. which one would that be. thanks
