[WANTED] 833 shifting forks
Not sure if it matters ? But I would be willing to take what I can get.
It does matter
you can retrofit the later steel forks into the older covers by cutting the interlock stubs off. but
you cannot run the brass forks in the later covers.
But you can run either cover with it's matching forks on any year box.
It does matter
Wow, I did not know that. Thank for the info
Well you can but the interlock mechanism will be bypassed and so there is nothing to prevent the engagement of two gears at once, if something goes wrong.
And more importantly? there is no detent to keep the selected gear engaged or to prevent over-travel.
