[SOLD] 87 D250
niceolddart
S.E. Pa.
318 4 speed, one previous owner. Showing 99,000 miles on odometer. Sure Grip Dana 60. Not pretty but a decent work truck. Was inspected until May of this year, body kind of rough, underside pretty solid. All cab mounts good, frame good, drives & stops good (drove truck to my house about 2 miles) Starts right up. Everything works. Still working on getting truck cleaned up, has some dirt & mildew on body. I will answer any questions you might have. Good heavy duty truck. Asking $2700. 19030 zip code, S.E. Pa.
Will trade for Duster of equal value. Slant 6 car is fine but car must be close to stock (not messed with too much) & good frame. Prefer a running car but not written in stone.
Repaired drivers side rust hole. Has new rubber floor mat, T/S switch, dimmer switch, 2 Halogen headlights, wiper blades. 4 Good Dunlop tires, newer front brakes & calipers, rear wheel cylinders. Will need for safety inspection in Pa.- rear brake hose, L.R brake adjuster (frozen) should have brake lines on rear replaced, frame rails over rear axle patched where bump stops were. May need upper control arm bushings by next inspection. $2000 obo. S.E. Pa. 19030 zip code. MUST SELL! Make a reasonable
