Merrell B Jennings
Member
Just need to know if this motor has a fuel pump eccentric? Its throttle body injection.
Thank you!!!yes, it should have one.
Welcome to the site !Thank you!!!
Thank you. I ended up getting a 89 318 throttle body injection. Which do you think is best, 2 barrell or 4 barrel carb on that motor. I have a 600 cfm edelbrock carb already, but im looking for the best running setup.Welcome to the site !
I would get a dual plane 4bbl intake. Shop 2nd hand or buy new. Weiand Action plus would be a great intake for it. But many, many intakes available. the 600 eddy carb is a good carb and will run it well, but not the best performance carb in my opinion. Should work well for you though.Thank you. I ended up getting a 89 318 throttle body injection. Which do you think is best, 2 barrell or 4 barrel carb on that motor. I have a 600 cfm edelbrock carb already, but im looking for the best running setup.
I believe that the Edelbrock 600 carb is a square bore carb... The Wiand Action Plus is a spread bore intake...
I would recommend the Wiand Stealth over the Action Plus as it's a square bore intake that will match the carb better without having to use a restrictive adapter...
Also the Wiand Stealth is rated from idle - 6800 RPM, where the Action Plus is rated from idle - 6000 RPM... The Stealth can go 800 more RPM on the top end and still pull strong off idle...
Stealth:
Weiand 8022WND Weiand Stealth™ Intake - Chrysler Small Block V8
Action Plus:
Also to the original poster - Welcome to FABO.... View attachment 1715327402
no adaptor needed. I'm running a Action plus on my 318 with a Holley 770. As I said, many choices. Action plus is cheaper and will perform great on that 318. IF a person wanted to add a 12 dollar eddy square plate, fine. Sell them at any O'reilly's or ebay, etc
right now I have 2 Action plus intakes and 1 stealth. Stealth is comparable to the Eddy RPM (not airgap), and the power added to the top comes from some on the bottom endI wasn't sure if a square bore carb would bolt on the Action Plus without an adapter... I've never tried that combo before...
But I still like the Stealth a little better as it has 800 more RPM on the top end...
Isn’t Krazy referring to the Edelbrock carb on the weiand intake?no adaptor needed. I'm running a Action plus on my 318 with a Holley 770. As I said, many choices. Action plus is cheaper and will perform great on that 318. IF a person wanted to add a 12 dollar eddy square plate, fine. Sell them at any O'reilly's or ebay, etc
yes, that changes nothing.Isn’t Krazy referring to the Edelbrock carb on the weiand intake?
Most any dual plane will work well and the 600 CFM Carb will fill the bill just fine.Thank you. I ended up getting a 89 318 throttle body injection. Which do you think is best, 2 barrell or 4 barrel carb on that motor. I have a 600 cfm edelbrock carb already, but im looking for the best running setup.
Headers and hei ignitionMost any dual plane will work well and the 600 CFM Carb will fill the bill just fine.
Have there been anymore modifications to the engine?
