[WANTED] 9” Drum Spindles
Cars and Mopar Parts Wanted
Thread Status:
  1. Redfoxestco
    Redfoxestco Well-Known Member
    76
    30
    Oct 20, 2020
    Los Angeles
    Local Time:
    10:03 AM
    Contact Seller
    Desperate to finish this front brake Wileood conversion but only have the KH front spindles on. In SoCal, can anyone point me in the right direction of where to locate a pair?! Thanks in advance
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    79,526
    58011
    Jun 7, 2010
    Georgia
    Local Time:
    1:03 PM
    9" drum brake spindles? I do believe I have a pair.
  3. Redfoxestco
    76
    30
    Oct 20, 2020
    Los Angeles
    Local Time:
    10:03 AM
    Rusty! That would be incredible. How much would you like? Any chance you can FedEx em over? I was just in GA. if it’s easier I can send someone to pay you and pick em up, that way you don’t have to deal with all the shipping malarkey
  4. RustyRatRod
    79,526
    58011
    Jun 7, 2010
    Georgia
    Local Time:
    1:03 PM
    Yeah I'd go for that. I don't know. Whatchyoo wanna pay? lol You want JUST the spindles, right? I'll have to take um off the backin plates, but oh my God that's such a five minute headache. LOL
    • Like Like x 1
    • Redfoxestco
      76
      30
      Oct 20, 2020
      Los Angeles
      Local Time:
      10:03 AM
      Just the spindles and bolts. If no to bolts, that works too. How does $100 for the pair sound? Or I’ll send back the backing plates so you don’t have to! Lol
    • niceolddart
      niceolddart FABO Gold Member FABO Gold Member
      437
      293
      Dec 19, 2014
      S.E. Pa.
      Local Time:
      1:03 PM
      I don't know what the difference between 9" & 10" drum spindles are, aside from the backing plates, but I have 2 10" front assemblies from a 69 Dart GTS. Spindles, backing plates & all the bolts, spindle nuts & washers, good shape & clean if that will work for you. I think I can fit it all into 1 USPS large flat rate box, (would be about $23 shipping)so price with all this including shipping to you from Pa. would be just about $175. I can take pictures if your interested or RustyRatRods deal doesn't work out for you. (Don't want to step on anyone's toes)
    • SGBARRACUDA
      SGBARRACUDA ROY FABO Gold Member
      21,517
      10017
      Dec 7, 2006
      PLANT CITY FL. and PERRY GA.
      Local Time:
      1:03 PM
      I’m thinking the Wilwood kit the OP wants to use calls specifically for 9” spindles.
    • Redfoxestco
      76
      30
      Oct 20, 2020
      Los Angeles
      Local Time:
      10:03 AM
      Yes, thank you for your quick step in and help niceolddart but unfortunately it calls for 9”.
    • niceolddart
      437
      293
      Dec 19, 2014
      S.E. Pa.
      Local Time:
      1:03 PM
      Not a problem. Can you, or someone tell me the difference between the two spindles? Maybe the spindle shaft diameter or backing plate bolt holes are different. I really don't have a clue. + it would be another piece of knowledge that I have. Thanks.
    • SGBARRACUDA
      21,517
      10017
      Dec 7, 2006
      Local Time:
      1:03 PM
      9” and 10” are completely different. Different bearings and spindle diameter.
    • Oldmanmopar
      Oldmanmopar Going left turning right FABO Gold Member
      9,479
      6354
      Jan 8, 2009
      Danielsville Pa. 18038
      Local Time:
      1:03 PM
      I can post pics of them side by side if you really need them . But Rusty should have you covered. At the price that was stated he is giving them away. I used Strange brakes that called for 73 up disc spindles. The reason I switched was I wanted 2 inch drop spindles and were only available for 73 up . Close to $500 a pair.
      The 9" spindles have small bearings and also take small ball joints. I was going with wilwood until I found that no drop spindles were available for the 9" application. I decided to go with strange race brakes and I am glad I did. I could not get an answer from either , Strange or magnum force if they would work together? They fit right up. Fat man are welded up steel. Magnum force are stronger drop forged and worked perfect for are new car build. No welds to rely on.
      Magnum Force Mopar 2 inch dropped spindles for Dodge and Plymouth
      • Thanks! Thanks! x 1
      • Oldmanmopar
        9,479
        6354
        Jan 8, 2009
        Local Time:
        1:03 PM
        as you can see the 9 inch first pic are totally different and have a right angle ball joint attachment where all others have a stronger straight on attachment
        [​IMG]
        [​IMG]
      • RustyRatRod
        79,526
        58011
        Jun 7, 2010
        Georgia
        Local Time:
        1:03 PM
        You can have the drums and all. Unless you just slap don't want all of it. Either way. Just let me know "WHAT" and "WHEN". LOL
      • RustyRatRod
        79,526
        58011
        Jun 7, 2010
        Georgia
        Local Time:
        1:03 PM
        Just shoot me a PM and we can go from there.
        • Like Like x 2
        • niceolddart
          437
          293
          Dec 19, 2014
          S.E. Pa.
          Local Time:
          1:03 PM
          Thanks SGBARRACUDA, for the info on the difference between 9" & 10" spindles. Now I know.
          • Like Like x 1
          • Agree Agree x 1
          • davescuda
            davescuda FABO Gold Member FABO Gold Member
            11,018
            2141
            Apr 30, 2007
            Cheshire, CT
            Local Time:
            1:03 PM
            I have a real nice set. if still needed
          • davescuda
            11,018
            2141
            Apr 30, 2007
            Cheshire, CT
            Local Time:
            1:03 PM
            pictures
          Thread Status:
