my 95 ram has a 9.25 it started making pinion bearing noise at 70k. i put m1 synthetic oil in after that and lived to 177k, drag duty,truck duty, dumb teenager stuff too, never had a problem. weakest link is the crush sleeve and c-clip axles. :read2:watch out for the 2 different versions, i ran into this with my ramcharger. i believe they changed c-clip thicknesses in 81. i had an early lsd that i wanted to use but couldnt because of the c-clips in my 89 were thicker. you had to jam the axles in to get the c clips to seat but the drum would bottom in the backing plate, when you pulled back out there was no way to get the x shaft through. other than the axle dilema of resplining with c-clips id say go for it.
my $.02
