903 Slant 6 tranny info
Vali68
California
Anyone know the dimensions for a 903 Slant 6 tranny?
I think the length is 31", but not sure of the height or width of the biggest part which is the bellhousing.
I measured approx. 18" across the widest point which is where the starter is mounted.
Kevin
It's a 904,they didn't make a 903. All slant 6 engines used a 904. What are you trying to figure out?
Are you sure all /6's used a 904? I believe some trucks and early vans had a 727. In regards to what he wants to know is, height and width on the belhousing. I gave him a trans and he wants to try and figure out if it will fit in the trunk of his Avalon before he comes to pick it up.
Kevin
A 903 is a manual 3 speed transmission used behind slant sixes from 62 thru maybe 69. It's a non syncro 1st gear is this what you are asking about?
Brian
