Wheel Chock
I have a 72 904 on which I did the wide ratio gear swap about 10 years ago. I am now going through it as I am replacing the engine in my Duster and I would like to install the 5 clutch drum and wide band from a 999. I have the drum and band, but am running into a clearance problem with the pump. The 4 clutch and 5 clutch drum have the same inside diameter where the sealing rings ride, however the 5 clutch drum makes contact at several points around the pump stator. It appears that I could dress these points with an angle grinder in order to get clearance. Is this the way to go or is there another (inexpensive) approach that I should take?
