904 front drum 5 disc wet @ .045
Transmission and Drivetrain Tech
  1. 70Roadkill
    70Roadkill Well-Known Member
    568
    82
    Apr 2, 2017
    Dexter
    Local Time:
    1:36 PM
    so I have my 5 frictions and steels all in the front drum, running a .060 snap ring and this is with the frictions soaked in atf. I can only get .045 feeler gauges in there. Just trying to figure out how much soaked vs. dry what the gap should be and if I need to get the plate milled or just pull out a friction and go with a 4 disc and leave an extra steel in to keep a proper measurement.
    I looked through lots of threads and everyone likes to see .010-.015 per disc clearance. But I wasn’t sure if that was a wet or dry measurement. Thanks in advanced for your replies.
  2. TXDart
    TXDart Legandary Member Legendary Member
    3,910
    948
    Feb 11, 2011
    CENTRAL TEXAS
    Local Time:
    12:36 PM
    I got .010 dry,
    5 clutches and steels.
    Big fat steel on top.
    Mines to tight and looking for .075-.080" at top pressure plate and snap ring.
  3. 70Roadkill
    568
    82
    Apr 2, 2017
    Dexter
    Local Time:
    1:36 PM
    Just so I’m clear, you get a total of .050 so .010 clearance per friction? Or when you assemble it all and you put your feeler gauge between the plate and snap ring you only get .010?
  4. CudaFactHackJob
    CudaFactHackJob FABO Gold Member FABO Gold Member
    1,508
    564
    Mar 17, 2016
    Hemet, Ca.
    Local Time:
    12:36 PM
    You know what sometimes the clearance will change when you assemble the drum onto the pump and air check it. No, not .010 total. I don't go by the .010-.015 per disc because the packs can be anywhere from 3 to 6 discs. And .030 is too tight and .090 is too loose.
  5. TXDart
    3,910
    948
    Feb 11, 2011
    CENTRAL TEXAS
    Local Time:
    12:36 PM
    I just started messing with mine today.
    My snap ring id .060,guess I need to machine pressure plate.
  6. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    16,039
    4674
    Jan 16, 2005
    las vegas
    Local Time:
    10:36 AM
    measurements are dry.....are you using the thin clutch disc?....like .061 ?
  7. 70Roadkill
    568
    82
    Apr 2, 2017
    Dexter
    Local Time:
    1:36 PM
    .068 steels and .061 frictions.
  8. 70aarcuda
    16,039
    4674
    Jan 16, 2005
    las vegas
    Local Time:
    10:36 AM
    on all 5 or 6 904s that I have converted from 4 disc to 5 disc i had to machine the pressure plate to get to .070.....last one I had cut a .020...
    and the pressure plate are case harden steel
  9. CudaFactHackJob
    1,508
    564
    Mar 17, 2016
    Hemet, Ca.
    Local Time:
    12:36 PM
    That is some tuff steel. You can use the lower pressure plate from a forward clutch, just check the clearance to make sure it doesn't contact. anything.
  10. 70Roadkill
    568
    82
    Apr 2, 2017
    Dexter
    Local Time:
    1:36 PM
    Took it to my buddies place, took a little off of it and now sitting at .065 clearance. Gonna let we ride. Time to assemble it and air check it all.
    • Like Like x 1
    • fishy68
      fishy68 Tyr Fryr's Inc. FABO Gold Member
      16,951
      945
      Jan 11, 2005
      Central, IL (Hooterville)
      Local Time:
      12:36 PM
      I've always had to machine the pressure plate down with 5 discs too. And I always measure them dry. Not sure how much diff wet makes but i'd think you should be fine at .065
    • CudaFactHackJob
      1,508
      564
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      12:36 PM
      They're different wet than dry. Once soaked you need to air check the drum on the pump to squish out the extra fluid to get the final clearance number.
    • VOETOM
      VOETOM Well-Known Member
      934
      363
      Jul 27, 2008
      KC, MO area
      Local Time:
      12:36 PM
      An easier way is to use the Alto Powerpack. They come with thinner steels and/or frictions and some have the thinner pressure plate.
    • CudaFactHackJob
      1,508
      564
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      12:36 PM
      Watch those "complete" kits. They sell you altos for the direct pack in sets of thick fours. I have a hard time finding enough thin altos to do the forward and direct for the 904. The 727s I can find direct only packs with 6-7 altos and thin top plate for around 85.
