Did you get your kickdown cable installed? On this Duster, it wasn't adjusted properly. The transmission would stay in gear way too long and shift hard. Was told the trans had a shift kit in it. Maybe, but maybe not. At 45 mph, with light throttle, it was still in 2nd gear and I would have to gas it, then let off the gas pedal quickly to get it to shift to 3rd. After adjusting the cable at the carb, I got it to shift normally. I'm not so sure about a shift kit because it shifts smoothly now. Before, it was like yanking gears with a manual, which I like if done properly.
