1. KJoeZ61
    KJoeZ61 FABO Gold Member FABO Gold Member
    375
    84
    Apr 4, 2017
    Northampton Pennsylvania
    Local Time:
    11:14 PM
    I'm sure this has been asked before but I cant find it. The attached picture shows my linkage as it rests. My question is the lever on the transmission can travel about a half inch more at full throttle, but wont as it's adjusted. So should I adjust it more that the lever on trans is more engaged at rest?
  2. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast"
    4,345
    1684
    Dec 27, 2013
    PHX
    Local Time:
    8:14 PM
    Could it be because you have a 2 barrel top rod linkage and not a 4 barrel? It looks like you’re holding on to 3/4 threads with leads me to believe so.
    Jake
  3. H22A4
    H22A4 Does anyone read this?
    2,323
    1240
    Aug 4, 2006
    YVR
    Local Time:
    8:14 PM
    What’s the geometry look like of that linkage from the throttle bracket to the carb? With a lot of threads visible on that linkage, you might have a 2bbl rod trying to do the job of a 4bbl rod.
    Here’s a comparison of a 2bbl rod and 4bbl rod.
    [WANTED] - 4-bbl kick-down rod
  4. zombywoof
    zombywoof Well-Known Member
    443
    178
    Nov 2, 2014
    in the dog house
    Local Time:
    10:14 PM
    • Agree Agree x 2
    • krazykuda
      krazykuda Well-Known Member FABO Gold Member How-To Section Editor
      60,451
      26614
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      10:14 PM
      You can use the 2 bbl rod on the 4 bbl if you add about 1 1/2" more thread...
    • Jadaharabi
      Jadaharabi FABO Gold Member FABO Gold Member
      8,681
      10277
      Jan 8, 2016
      Peoria, Illinois
      Local Time:
      10:14 PM
      At wide open throttle, when you push back on that kickdown linkage, you should have approximately a quarter of an inch of play.
      You do not want the kickdown linkage to bottom out that kickdown lever on your valve body. you can break things or pull things apart inside where the valve for the kickdown is.
      • Agree Agree x 1
      • BILL MATCHETTE
        BILL MATCHETTE Active Member
        25
        8
        Jun 26, 2018
        Arizona
        Local Time:
        9:14 PM
        What RPM does it shift @ WOT ?
      • Jadaharabi
        8,681
        10277
        Jan 8, 2016
        Peoria, Illinois
        Local Time:
        10:14 PM
        It would depend on the adjustment of the kickdown linkage. And the Governor weights on the tail shaft inside the transmission.
      • KJoeZ61
        375
        84
        Apr 4, 2017
        Local Time:
        11:14 PM
        There is no way I can make it any longer, not even a quarter of an inch. If I go any longer it won't fit on the throttle linkage without binding. The first picture shows it resting without the spring. Second picture shows throttle floored the the kick down as far back as it will go.
      • H22A4
        2,323
        1240
        Aug 4, 2006
        YVR
        Local Time:
        8:14 PM
        The angles/geometry of your throttle/pedal cable is off. It should be in a straight line from the throttle cable/kickdown bracket to the carb attachment. You’ve got the same problem with the kickdown rod too.
        You may need an adaptor for Mopars for your carb which corrects that geometry.
        • Agree Agree x 1
        • zombywoof
          443
          178
          Nov 2, 2014
          in the dog house
          Local Time:
          10:14 PM
        • dusted
          dusted FABO Gold Member FABO Gold Member
          614
          604
          Sep 24, 2006
          Creedmoor, NC
          Local Time:
          11:14 PM
          Ditch the linkage altogether and get you a cable conversion from Bouchellion or Lokar. Solves most of the problems and easily adjustable. You can always sell the linkage and recoup some money.
          • Disagree Disagree x 1
          • forphorty
            forphorty Well-Known Member
            791
            405
            Jan 19, 2006
            Local Time:
            10:14 PM
            Ditch the linkage altogether and install a manual valve body. Solves all the problems and shift points are easily adjusted with your right arm.:D
            • Like Like x 2
            • Jadaharabi
              8,681
              10277
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              10:14 PM
              In the second picture you need to screw the end on to the rod so that you have a quarter inch of free travel at wide open throttle with the linkage all the way back.
              In the first picture it does not matter where that linkage sets once you put the spring on it it will pull it Forward against the pin. The purpose for that long slot is so that if your kickdown linkage binds your throttle can return to idle. What counts is at wide open throttle you have a quarter inch or so of play to keep from bottoming out the kickdown. You do not need to extend that rod in the second picture you need to screw the end on so it slides over that throttle pin.
            • BILL MATCHETTE
              25
              8
              Jun 26, 2018
              Arizona
              Local Time:
              9:14 PM
              I was asking the OP
            • Jadaharabi
              8,681
              10277
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              10:14 PM
              I'm so sorry. Please forgive me.
            • Jadaharabi
              8,681
              10277
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              10:14 PM
            • KJoeZ61
              375
              84
              Apr 4, 2017
              Local Time:
              11:14 PM
              Does this look any better? Is this the correct spacing
            • Jadaharabi
              8,681
              10277
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              10:14 PM
              In tbe first picture you need to push the kick down back as far as it will go at the same time the throttle is all the way back. Then adjust to the pin.
              If in the picture it is all the way to the back then you need to adjust it back(forward) for Less gap between the pin and the slot.
            • BILL MATCHETTE
              25
              8
              Jun 26, 2018
              Arizona
              Local Time:
              9:14 PM
              The linkage between bell crank & trans needs adjustment.Do you see the hole in bell crank?Disconnect that rod, then put a drill bit in the hole then push link down and adjust it so it just snaps back on .
            • KJoeZ61
              375
              84
              Apr 4, 2017
              Local Time:
              11:14 PM
              I though we were going for a 1/4" gap there. Your saying close the gap so it's just about touching?
            • Jadaharabi
              8,681
              10277
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              10:14 PM
              You will feel the play at the end of the travel.
              If in that picture the travel is all the way at the back I would close that Gap to about half of what it is but once again just goes by how it feels at wide open throttle. Just don't force it.
              Drive it try it out.
            • KJoeZ61
              375
              84
              Apr 4, 2017
              Local Time:
              11:14 PM
              Thanks, I'll do the final adjustment and see what happens tomorrow.
            • 1969reddart
              1969reddart or is it Copper...
              310
              329
              Sep 29, 2007
              Concord, Ca.
              Local Time:
              8:14 PM
              • Like Like x 1
              • SGBARRACUDA
                SGBARRACUDA ROY FABO Gold Member
                21,540
                10042
                Dec 7, 2006
                PLANT CITY FL. and PERRY GA.
                Local Time:
                11:14 PM
                I have a brand new Lokar kick down still in the package if that will help you.
