904 Leaking small amount of fluid after rebuild.
Transmission and Drivetrain Tech
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    520
    125
    May 18, 2019
    Indio California
    Local Time:
    2:08 AM
    I recently rebuild the 904 in my 73 Valiant, when I installed the torque converter (stock) back in I drained it and filed it up as much as it would take (a little under 3 qts) and poped it in.
    After I installed it in the trans it would leak a little for about 2-3 days just sitting there as the car has not ran yet. It seemed to stop. A few days later i added 4 qts into the trans making it about 7 qts full. It is now leaking again from the inspection cover area. I wiped it and will check again tomorrow and see if it stops on its own. Is there anything that would cause this? Ive read something about a vent?
    Main thing is I would rally hate to take the trans off again. It has a new TC seal, pump outer seal, and bolt washers.
  2. Frankie Cuda
    Frankie Cuda New Member
    2
    1
    Sep 2, 2020
    New York
    Local Time:
    5:08 AM
    Start it up if you haven't already. you may just have to seat the seal. If the engine doesn't run just crank it. Good luck
    • Thanks! Thanks! x 1
    • C2ndLTpigeon
      520
      125
      May 18, 2019
      Indio California
      Local Time:
      2:08 AM
      Thanks for the tip, I will give it a try, and pray thats it!
    • charger426
      charger426 Well-Known Member
      960
      104
      May 5, 2014
      MoparLand
      Local Time:
      5:08 AM
      Have the same problem with my 727. I think it’s the crush washers I didn’t change that bolt the front pump in. I looked at my old washers and didn’t know they were one use and reused them. Now when I fill my trans up it leaks. BUT once it gets about a qt low it stops. Sooooo since I have a +2qt trans pan I’m not super stressed about it BUT you might have the same washer problem I think I have.
    • C2ndLTpigeon
      520
      125
      May 18, 2019
      Indio California
      Local Time:
      2:08 AM
      The kit came with new ones which were used and bolts torqued to spec
    • CudaFactHackJob
      CudaFactHackJob FABO Gold Member FABO Gold Member
      1,651
      623
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      4:08 AM
      A worn converter or pump bushing..or the fluid that dripped out of the converter when you installed it is dripping out of the bottom of the bell..park the car so the front is down so it all runs out. Did somebody strip out a front pan bolt and have to drill and helicoil it? Might have broke thru to the outer edge of the pump.
    • C2ndLTpigeon
      520
      125
      May 18, 2019
      Indio California
      Local Time:
      2:08 AM
      Pan is good no striped bolts. Transmission had a complete rebuild by me, all seals installed, like I mentioned before I filled the converter and installed it. I leaked a little but stopped, I assume the fluid made its way into the trans from the converter and when it leveled out it stopped? A few days go buy I add 4 qts, and it does it again, I will make note if there is any in the morning.
      Car has not been fired up yet, so im not sure if it will change. Like mentioned before maybe the seal is not seated.
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      73,078
      48563
      Jun 7, 2010
      Georgia
      Local Time:
      5:08 AM
      You make zero mention of what the dipstick reading is OR where you have the shifter when checking fluid OR if you even checked it at ALL. Did you "just add" fluid without checking it?
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      19,308
      6465
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      4:08 AM
      7 quarts are too much if the trans hasn’t run. It’s over full. Take some ATF out. If u do ever check it u will see what we mean. The converter drains back into the pan also. I’ve seen this a few times b4. Kim
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      7,930
      7133
      Jun 1, 2016
      Beach
      Local Time:
      2:08 AM
      Cycle it through the gears..cant fill it till running and circulating.There is a vent it could blow out, yes.
      Btw if you put the seal in dry, the converter will probably burnt it.
    • TrailBeast
      TrailBeast AKA Mopars4us on Youtube
      21,710
      9535
      Mar 11, 2011
      Arizona
      Local Time:
      2:08 AM
      The tension spring inside the pump seal can jump out from the shock when putting the seal in.
      This is why some pack the seal with assembly lube before it get installed.
      The vent is way too high for fluid to come out when not being run unless it’s just way overfilled. (Way over)
      Generally the vent is for fluid that foams up from the rotating assembly running in too high of fluid levels.
      Not saying this is the problem, just that it does happen.
      • Agree Agree x 1
      • C2ndLTpigeon
        520
        125
        May 18, 2019
        Indio California
        Local Time:
        2:08 AM
        Fluid was a little high, so I removed about a qt as Kim recommended, now the level is at the full line.
        This morning there was no fluid underneath the bell housing but a there was a light film behind the inspection cover, but not enough to make a puddle, Im thinking it having to much may have been causing it to run out?
        I will see what happens when it runs. Should be in the next 2 weeks. I just wanted to make sure the trans had enough fluid for start up so it doesn't burn things out. Guess I added to much. Lesson learned for next time.
      • CudaFactHackJob
        1,651
        623
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        4:08 AM
        Make sure you don;t run the motor more than a minute if the trans isn't to the full mark. People waiting for the trans to warm up end up burning bushings and washers.
        • Like Like x 1
        • C2ndLTpigeon
          520
          125
          May 18, 2019
          Indio California
          Local Time:
          2:08 AM
          As of now it has 2 1/2 in the converter and 3 in the trans now since I removed about a Qt, will add when its running.
          • Agree Agree x 1
          • CudaFactHackJob
            1,651
            623
            Mar 17, 2016
            Hemet, Ca.
            Local Time:
            4:08 AM
            5.5 left. Start it in NEUTRAL and immediately add 4 quarts. Check the level in neutral. There's no need to run it thru the gears; or move the shift lever at all. If you have to remove fluid, just unscrew the neutral safety switch.
          • C2ndLTpigeon
            520
            125
            May 18, 2019
            Indio California
            Local Time:
            2:08 AM
            I will do this in neutral then as the first start up will also be breaking in a new camshaft and I will not be able to switch gears for 20 min.
          • oldkimmer
            19,308
            6465
            Nov 11, 2006
            Local Time:
            4:08 AM
            Don’t they only hold 6 or 7 we quarts to begin with? Wouldn’t it be way over full with 4 more in it. Then puke it out? Kim
          • CudaFactHackJob
            1,651
            623
            Mar 17, 2016
            Hemet, Ca.
            Local Time:
            4:08 AM
            Not with a dry converter. 6-7 won't fill it.
          • C2ndLTpigeon
            520
            125
            May 18, 2019
            Indio California
            Local Time:
            2:08 AM
            Converter is not dry, 2.5 qts were added before I installed the trans, and 3 more qts were added making 5.5 in it now. I believe factory manual says max is 8.5 qts
          • CudaFactHackJob
            1,651
            623
            Mar 17, 2016
            Hemet, Ca.
            Local Time:
            4:08 AM
            I wouldn't be afraid of overfilling it if you aren't going to even put it in gear. I started one up once and added all the fluid because I knew exactly how much it would take. I forgot to start it in neutral tho, so fluid started running out the vent in the bell housing. When I saw it dripping, I pulled the stick and it was about six inches above the full mark. I jumped in the car and put it in neutral, jumped back out and checked it and it said LOW. I added half a quart and drove it immediately and it was fine.
            • Like Like x 1
            • C2ndLTpigeon
              520
              125
              May 18, 2019
              Indio California
              Local Time:
              2:08 AM
              Checked the floor again today and not a drop which seems to be a good sign.
