nm9stheham
A.K.A. friction modifier..... (I personally would look to someone like Lubegard for such trannie additives.)An old home remedy for shudder is limited slip/sure grip additive. Works wonders.
Seriously. This stuff was recommended for my 2006 Sprinter. These vehicles were notorious for converter shudder from new in the lower RPM range. I was advised at the time that the shudder is more of an annoyance than a problem.
My understanding is that ATF+4 has some amount of friction modifiers, as do most modern ATF's.
The Instant Shudder Fixx above will show if TC lockup is the source. And it will indeed work very quickly.... like in less than a mile, you will notice a change. So it is a good diagnostic tool. There are longer life additives intended to last for many thousands of miles like this one which would be added if the Instant Shudder Fix helps: Highly Friction Modified ATF (HFM-ATF) Supplement with LXE® Technology
And BTW I have used these products the help reduce TC shudder in a Ford Taurus that had developed severe shudder issues. It helped and reduced the problem from severe to the 'sometimes annoying' level, but ultimately it would need a renewed VB and/or solenoid pack, or a new TC, to fully fix this particular car's issues.
But there are other sources of TC lock issues like wear in the valve body or other apply pressure mods, which I assume is what is being done with the suggested pressure adjustment. Also VB mod kits like have been suggested.
trying to get the larger image on.Hard to read some of that but many thanks, and I'll keep reading it. I love the diagnosis wheel!
I can email to whomever sends me a message with your address. I can't seem to get it to post clear and larger.
Does it still shutter? Did not watch yet.
How long was the 1st test drive? The new ATF+4 fluid may have now 'conditioned' the used TC lock clutches so that they engage smoothly.Thanks Tom, nope shudder was gone after 1st test drive. 2nd drive out none and no changes were made at that point.
So I am bit confused.... but that is nothing new! I reviewed this whole thread, and also the prior thread. So is this a different trannie, with a lock-up TC, than the one that was being rebuilt in the prior thread?
