904 rebuild kit
mopardemon340
WI
im going to be calling around for prices to rebuild my 904 but if i cant find a place that will rebuild at a good price i will rebuild it my self.. whats the best rebuild kit to use. this 904 will be behind a 408 stroker so will need to handle some hp and torque. i already have the book for the trans to rebuild it.
this is everything i need correct.. then if i want a shift kit ill have to buy that to seperate.
Number:AK125A
Description:MRK DELUX MASTER KIT 904, TF6 72-88
(4 DIRECT FRICTIONS, 4 FORWARD FRICTIONS) SPRING AND ROLLER KIT 10 SPRINGS & 10 ROLLER NO CAGE TYPE INCLUDES:(AR125H-R, 12030B, A12024A, A12654, 12139)
Includes: All Friction & Steel Plates, Front & Rear Bands, Bushing Kit, Filter, Clad Seals, Sealing Rings, Gasket/Seal kit
Steels are included in the MRK DELUXE KITS. The steels are also available separately in the clutch plate section. Find them under the table of contents
Price:$134.69
AK125A
How much horsepower are u putting to it? Im about to do my first rebuild. I am running about 400hp. I went with alto clutches. Raybestos steels. Billet servos and accumulator piston. Billet strut bar and 4.2 lever. And a bolt in super sprag. Fingers crossed it all works lol
