1. Cope
    Cope Fusing with fire
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    3:30 AM
    Took my car out for a drive today and it won't up shift out of first.
    Fluid is full and clean, no adjustments to the linkage lately.
    I did do a few Smokey burnouts last night in the shop parking lot....
    What do you think is the issue?
    Thanks again.
  2. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    47,999
    13377
    Jun 7, 2010
    Georgia
    Local Time:
    4:30 AM
    Did you try shifting it manually?
  3. TrailBeast
    TrailBeast Slightly Twisted Member
    19,224
    5567
    Mar 11, 2011
    Arizona
    Local Time:
    2:30 AM
    The thing that is the most common and comes to mind first is that there is metal powder in the fluid and when it settled in the valve body over night it sticks the shift valve the next drive.
    I would pull the pan and look close at the bottom of it purely for the information it gives.
    If it were a broken second gear band or servo issue it would shift directly from 1st to 3rd.
    The last one I saw do what yours is doing it would free up eventually and start shifting again but the next morning it was stuck again.
    Turned out to be the rear planetary set needle bearings disintegrating.
  4. inertia
    inertia Well-Known Member
    3,088
    425
    Feb 4, 2011
    Victoria B.C. Canada
    Local Time:
    1:30 AM
    Check your throttle pressure linkages haven't fallen apart and jammed WOT.
  5. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    3:30 AM
    Linkage is fine.
    The one two shift works manually when I shift into drive it slips then Rs way up.
    I think the new motor and that last burnout was the last straw....
  6. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    3:30 AM
  7. RustyRatRod
    47,999
    13377
    Jun 7, 2010
    Georgia
    Local Time:
    4:30 AM
    • Thanks! Thanks! x 1
    • RAT ROD AL
      RAT ROD AL FABO Gold Member FABO Gold Member
      904
      661
      Jan 18, 2013
      St. James City. FL.
      Local Time:
      4:30 AM
      As an Mopar ex drag racer, you never did you burnout in 1st gear. The sprag gear could explode. I don't think you would still have 1st after that.
      • Agree Agree x 1
      • Mopar Tim
        Mopar Tim FABO Gold Member FABO Gold Member
        14,482
        7291
        Nov 29, 2014
        vista CA.
        Local Time:
        1:30 AM
        Or for that matter, a transmission at all!!:lol:
        • Agree Agree x 1
        • RustyRatRod
          47,999
          13377
          Jun 7, 2010
          Georgia
          Local Time:
          4:30 AM
          The 904 does not suffer from that problem.
          • Disagree Disagree x 1
          • Mopar Tim
            14,482
            7291
            Nov 29, 2014
            vista CA.
            Local Time:
            1:30 AM
            Really? That I did not know. How do they avoid that?
          • RAT ROD AL
            904
            661
            Jan 18, 2013
            St. James City. FL.
            Local Time:
            4:30 AM
            do your burnout in 2nd
            • Agree Agree x 2
            • Mopar Tim
              14,482
              7291
              Nov 29, 2014
              vista CA.
              Local Time:
              1:30 AM
              Yea I know that, RRR said 904,s don't have the sprang issues.
              • RAT ROD AL
                904
                661
                Jan 18, 2013
                St. James City. FL.
                Local Time:
                4:30 AM
                And trust me on this . A 904 will also, been there done that.
                • Agree Agree x 1
                • Bighead440
                  Bighead440 Well-Known Member
                  153
                  96
                  Jun 18, 2017
                  Milledgeville, Georgia
                  Local Time:
                  4:30 AM
                  Sounds like the direct (front) clutches are toast. Repair and make certain the throttle linkage is adjusted properly or you will have problems.
                  Burnouts are critical with ALL Torqueflites. If you have an underpowered vehicle and are doing a burnout at the track with slicks, make sure the waterbox is good and wet or roll through and back-in again to paint-roller the tires good (rear only-lol). Start the tires turning ahead of the waterbox at mid-throttle in manual low and IMMEDIATELY shift to second and increase the throttle to maintain wheel speed (no bog). As quickly as possible, shift to "D" and maintain throttle or increase pedal until you are throwing some smoke. Then release your line-loc/brakes and as the vehicle rolls forward, release the gas and let the tires bite (chirp!!) while in HIGH gear. Roll to the lights and stage.
                  With a high-powered car or full race vehicle with slicks, do your water burnout starting in manual 2nd or high. NEVER let the tires bite except in HIGH gear, as this protects the transmission/low roller.
                  • Like Like x 1
                  • Oldmanmopar
                    Oldmanmopar Going left turning right FABO Gold Member
                    5,953
                    892
                    Jan 8, 2009
                    Danielsville Pa.
                    Local Time:
                    4:30 AM
                    You burned er up. But I bet it was fun doing it. You didn't ruin anything that wasn't on its way out. At least it was not far from home . Get another trans yours my friend is toast. You'll get more into it than its worth.
