904 trans disengages then reengages
Transmission and Drivetrain Tech
  1. Clifb
    Clifb FABO Gold Member FABO Gold Member
    8
    0
    Sep 24, 2017
    Harvest ALABAMA
    Local Time:
    2:17 AM
    64 Barracuda 273 2 barrel stock throttle linkage to 904 push button trans. While driving in 3rd steady rpm, the trans disengages engine revs up and will re-engage again. then repeats it again -- Is this a trans issue - rebuild time or linkage issue -- ff linkage what is fix ???
  2. Alaskan_TA
    Alaskan_TA Well-Known Member
    4,568
    2414
    Nov 12, 2004
    PA
    Local Time:
    3:17 AM
    Have you checked the fluid level?
    • Agree Agree x 1
    • Clifb
      8
      0
      Sep 24, 2017
      Harvest ALABAMA
      Local Time:
      2:17 AM
      Thanks for answer yes changed the fluid and trans filter 2 months ago to hoping to cure issue —just started it and re checked it right on mark
    • Tooljunkie
      Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
      9,654
      8100
      Jul 22, 2017
      Manitoba
      Local Time:
      2:17 AM
      Checked in neutral, transmission hot?
    • Clifb
      8
      0
      Sep 24, 2017
      Harvest ALABAMA
      Local Time:
      2:17 AM
      Correct brought it up to normal temp drove around block and it again dis engaged check fluid in neutral when I got home and was on the mark has me puzzled
    • TrailBeast
      TrailBeast Slightly Twisted Member
      19,786
      6310
      Mar 11, 2011
      Arizona
      Local Time:
      12:17 AM
      Stock filter setup, or an extension with a bigger pan?
      What was in the pan when the fluid was changed?
      Was a new filter put in when the fluid was changed?
    • pishta
      pishta I know I'm right....
      14,611
      4264
      Oct 13, 2004
      Tustin, CA
      Local Time:
      12:17 AM
      Ive had that same issue and I wasnt low, my filter was stuffed! But lack of fluid is the same cause. Have pump pressure checked. Should not be much at a trans shop.
    • Kern Dog
      Kern Dog Well-Known Member
      2,981
      2905
      May 23, 2010
      Granite bay CA
      Local Time:
      12:17 AM
      I have a similar thing with my Brother-in-laws 72 Duster. The shifter is in drive but the car will sometimes just act as if I popped it into neutral. manually shifting it seems to engage it again. Maybe my linkage needs a slight adjustment.
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      52,186
      19596
      Jun 7, 2010
      Georgia
      Local Time:
      3:17 AM
      Look at and smell the fluid. If it looks brown and not red and smells burned, you probably have a direct clutch issue. It's worth doing a transmission service on it to check the pan for debris. If the fluid is burned and you have debris in the pan, it's time for a rebuild.
    • Kern Dog
      2,981
      2905
      May 23, 2010
      Granite bay CA
      Local Time:
      12:17 AM
      I don't think that you are a dumbass. No.
    • Clifb
      8
      0
      Sep 24, 2017
      Harvest ALABAMA
      Local Time:
      2:17 AM
      Thanks for all reply’s stock trans pan and new filter 2 months ago pan had black grains not as coarse as sand I did not cut old filter open should of when I get home tonight I’ll take it out and then check fluid color and smell
    • KickDown
      KickDown Just a Brit in Germany
      292
      126
      May 22, 2014
      Gifhorn, Germany
      Local Time:
      9:17 AM
      Any issues in reverse? Might be a broken sealing ring on the reaction shaft support which seals the circuit to the front clutch.
    • Clifb
      8
      0
      Sep 24, 2017
      Harvest ALABAMA
      Local Time:
      2:17 AM
      Not sure when I take out tonight I’ll check am I looking for slippage when backing
    • T56MaxTorq
      T56MaxTorq Well-Known Member
      885
      287
      Dec 21, 2010
      CO
      Local Time:
      1:17 AM
      Sounds all like a linkage problem. Any way you could safely disconnect it from the transmission and go for ride?
      Is it possible the trans is just kicking down prematurely and what you’re feeling is a downshift from 3-2? Has the kickdown linkage been inspected and adjusted correctly?
    • Clifb
      8
      0
      Sep 24, 2017
      Harvest ALABAMA
      Local Time:
      2:17 AM
      I really appreciate everyone’s input to this issue hopefully it can be diagnosed with everyone help and get it fixed
      I’ll try the disconnect the linkage and see if it does same tonight and let you know
    • Clifb
      8
      0
      Sep 24, 2017
      Harvest ALABAMA
      Local Time:
      2:17 AM
      Raining really bad in Northern ALABAMA will try Wed night appreciate everyone help it will be solved
