904's Keep Failing on 67 Motor
Transmission and Drivetrain Tech
  1. 540slant6
    540slant6 Mopar SB Ripper
    666
    79
    May 21, 2015
    Berryville, VA
    Local Time:
    11:47 AM
    So I have a 67 spec forged crank 318 in my Duster with a 67 spec 904 Auto. However, the motor came from a Sattelite that had a 727. So I changed the flex plate and have now destroyed 2 904's. The first trans broke off the convertor shaft clean at the welds. The second one is now puking fluid out the front and is doing the same thing.
    My theory is that the 67 motor crank is only drilled for the larger 727 convertor snout. So the smaller 904 snout is walking in the crank and destroying the 904 sized convertors? Meaning that the 67 crank is drilled larger than the 904 convertor snout. I know that 67 is a weird transition year so any input is greatly appreciated.
    I'm at my wits end and running out of money......
  2. Plymouth 65
    Plymouth 65 Floorable Deplorable
    653
    446
    Jun 27, 2016
    Mich
    Local Time:
    12:47 PM
    I believe you are correct. The pilot on the 67 crankshaft is larger. I'm not sure what year 904 converter you are using but if it an early one the snout is the small diameter. They make a bushing that presses onto the small snout converters. If you are getting a new converter just get the one with the larger snout. I believe 68-72 904 converters used the large snout. Hope this helps !
  3. 540slant6
    666
    79
    May 21, 2015
    Berryville, VA
    Local Time:
    11:47 AM
    That does help! I had a hunch that the problem was the 67 crank. Now I need to fine the bushing to install the smaller convertor into the larger 67 crank.
    Thanks for your input!
  4. dart4forte
    dart4forte FABO Gold Member FABO Gold Member
    4,157
    570
    May 28, 2004
    Mesa, AZ
    Local Time:
    4:47 PM
    Common issue when using a 67 and earlier converter in a newer 318 crankshaft with the larger crank register. A buddy of mine who happens to be a member here and an accomplished machinist built me a spacer that fits over the converter snout. The spacer ID fits over the snout while the OD of the spacer fits the crank register.
    In the interest of respecting his identity and privacy I cannot give you his information however he does follow FABO so he may see this thread and offer his assistance.
    If not, any machinest with a lathe can fix you up. All he needs is the converter snout OD, the crank register ID and depth along with an explanation from you what your problem is.
  5. 540slant6
    666
    79
    May 21, 2015
    Berryville, VA
    Local Time:
    11:47 AM
    Thanks guys, I'm assuming no one makes a 904 converter with the larger snout so it sounds like the microsleeve is my only option.
  6. Plymouth 65
    653
    446
    Jun 27, 2016
    Mich
    Local Time:
    12:47 PM
    Incorrect, just get a 904 convertor from a later model year 68-72, they have the larger snout diameter.
    • Like Like x 1
    • Locomotion
      Locomotion Well-Known Member
      2,706
      255
      May 31, 2004
      Florida
      Local Time:
      12:47 PM
      Nope! Spline count is different between the older, small snout converters and the newer bigger snout versions. They do not interchange.
      (The lock-up converters don't interchange with anything older as well.)
      • Agree Agree x 4
      • 65Val
        65Val Average Length Member
        4,699
        709
        Oct 14, 2005
        Victoria, BC, Canada, EH!
        Local Time:
        9:47 AM
        • Thanks! Thanks! x 1
        • Plymouth 65
          653
          446
          Jun 27, 2016
          Mich
          Local Time:
          12:47 PM
          I stand corrected, the trans input shaft spline is different. Gonna have to go with the bushing !
        • MOPAROFFICIAL
          MOPAROFFICIAL Well-Known Member
          3,023
          2018
          Jun 1, 2016
          breakwater
          Local Time:
          9:47 AM
          Any convertor/ trans shop with a source for one can put '67 and earlier guts into a '68- up convertor
          Earliy spline count is like 19....while the '68 -up are 27.
          If it were the other way....either the crank register would need turned larger or the trans would need changed.
          • Agree Agree x 1
          • Charrlie_S
            Charrlie_S Well-Known Member
            2,428
            398
            Oct 17, 2005
            Silver Springs, FL
            Local Time:
            12:47 PM
            Easiest way is the adapter bushing. I have them for sale $25.00 shipped
            Send me a PM, if interested.
          • 540slant6
            666
            79
            May 21, 2015
            Berryville, VA
            Local Time:
            11:47 AM
            I'll send you a convo shortly!
          • 65Val
            4,699
            709
            Oct 14, 2005
            Local Time:
            9:47 AM
            Sorry Charrlie_S....I didn't know you had these as well.....:thumbsup:
          • 540slant6
            666
            79
            May 21, 2015
            Berryville, VA
            Local Time:
            11:47 AM
            So I still have the vibration and will check the motor and trans mounts. I guess the next item is to check my stock ballancer since it's the original front 67! May be time to upgrade.
