906 or 915 ?
44o gts dart
iowa
Quick question for all you knowledgeable people,,,, I am building a mild 440 for my dart,hoping for 450 horse. ,I have a virgin pair of open chamber 906’s that came with block,that I have to redo ,,,, but know of a set of ported and polished 915’s off a 67,,, stainless 2.14 and 1.8 valves,.HD springs, titanium retainers… which would YOU use… and what would be a fair price for the 915’s ( which were just pulled off a running engine ) thanks in advance
DO the 915s come with flow numbers? The 906s if redone and ported will be the devil you know, versus the devil you don't know.
I like the 915's but I choose my piston based on the 915's... The wrong piston could make them a very bad choice...
In my opinion you do not need 915 heads or even larger valves to make 450 HP. It all boils down to your budget and how you want to make the power. Get yourself an Edelbrock Performer RPM intake and you'll already have a huge start on the 450 number.
Tom
Here is a recipe for 467hp@5,600 RPM
906 heads (blueprinted, 2.14 / 1.81, Stage 1 port)
10.5:1 comp dome pistons for 88cc chamber
825 holley
284/.528/112 soilid
1.6 ratio rockers (yields .556 lift)
2.125 full length headers
I asked him if he knew that number, but he did not. He said he just pulled them off his 383 bracket duster racer that was running 10.70’s. He is going aluminum… they are 3 hrs away so I have to figure another 150 in fuel,, he had them listed for 1200 almost 2 weeks ago,,down to 1k now,,, money is always tight on my end, so I was gonna offer 750 and I pick up,,,I assume I will have that in my 906’s for hardened seats, a good valve job and ports matched…. They are probably worth 150,, 1969 casting numbers( they been cleaned, mag crack checked,, new brass freeze plugs..I am leaning on staying with my 906’s,, my 1969 block will get deck, squared, bored and line bored, balanced rotating assembly… I just want a powerful , reliable,, stock looking engine… in a original m code dart.
I would have either set checked over. Unless the 915's are a deal (like $500-600) and check out good (don't need any work) I would price out what it will take to get the 906 heads ready to run.
You may find it cheaper to buy a set of 440 source heads and be farther toward your hp goal. Even if you go that route have them checked out.Don't just assume they are ready to run.
The 906s flow better. I know which ones I'd use.
Unless you can be “all in” on the iron heads for way less $$$ than a set of stealths....... now would be the time to make the move away from the stock heads.
Buried in his post, “stock looking engine, these are going on an original m code dart” that’s a factory 440 DART SWINGER. so I bet iron heads are what he wants.
use the 906 heads. Are you using stock manifolds? Then you don’t need oversized valves.
remember this, It’s all about the combination.
No,,, I will run under chassis headers… have only left hand manifold but I realize they are too restrictive,,, have spoke to the original owner and when he put fender well headers on it ,,,,, it way way stronger,,,, it’s a rare m code 440 gts
@wirehead
I'm genuinely curious how can you disagree with my post, or what about it you disagree with? I literally built and dyno'd that exact combo, posted the videos and dyno sheets. That combo made 467@5600 / 514@3900-4100
I'll see if I can dig it up. This was some 20+ years ago, back when bigblockdart.com still existed, or was at least active.
It was this engine. Note the POS Indy dual place sitting on top of it.
Here’s one from about 25 years ago:
446
Trw L2266’s
Bowl blended 906’s, 2.14/1.81
Torker with Demon 650
General Kinetics version of a Comp 280H
1.6/1.5 rockers
1-7/8 x 3 headers
915’s and 906’s have the same intake port.
The ex ports are slightly different, and IMO the 906 port is the better of the two.
The closed chamber of the 915 gives it the overall edge though.
That being said, if I didn’t have a suitable set of 915 castings sitting on the shelf........ I wouldn’t pay the premium most seem to be asking for them.
That begin said, if I didn’t have a suitable set of 915 castings sitting on the shelf........ I wouldn’t pay the premium most seem to be asking for them.
But don't forget there are two 915 castings. There is also the standard 915 with the smaller exhaust valve. Their ports are not as large too, if I'm not mistaken.
446
Trw L2266’s
1.6/1.5 rockers
1-7/8 x 3 headers
That's not bad considering those Pistons usually net around 9.3:1 compression and that's a cam you can run a stock converter with and not much lift about .514 with a 1.6 rocker.
I wonder how necessary the 1.81 exhaust valve is in a factory cast iron head, my wondering comes from trickflow using a 1.78 ex valve. With a 2.190 intake valve
I'd think going bigger on the intake would be the ticket. ( Trickflow vs factory 906 ports not a fair comparison) but just a thought
I think you're thinking of the 516 heads, which are closed-chamber but have smaller exhaust valves and restrictive ports compared the 915s. I can't say I've seen/heard of a 1.60" exhaust 915, but I'm not into big blocks like I once was. If there is, though, I'd assume it's the same situation as LA 915 J heads: The only difference between 340 and 360 casting is the machining. The castings are identical.
I’ve never noticed any difference in the castings themselves.
They’re either machined for 1.6 or 1.74 valves(just like SB J heads can be 1.88 or 2.02, but they start out as the same casting).
