94 Dodge ram, 4x4. What trans?
General Discussion
  1. Cope
    Cope Fusing with fire
    4,976
    6419
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    6:28 AM
    So the trans went out in spectacular fashion in our shop truck. She let ALL the fluid out in about 5 seconds and has a lot of metal on the drain pan plug.
    Today i got the trans out, not fun as its about 5 feet long and heavy as...
    It looks to be a 727 but im not sure as my experience is only with 904s. So what is the (base model auto) trans? I need to order a rebuild kit.
    Also i thought it would be obvious as to where the fluid came out of but i dont see anything that stands out as the leak. I thought it would be the front pump seal but that is dry?
    Any ideas where it all dumped from? The entire trans is covered, so its hard to tell where the problem was..
    I will be tearing it apart tomorrow and will get some pics of the carnage for ya!
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    19,352
    6506
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    6:28 AM
    If it looks like a 727 it is a 518. Kim
    • Like Like x 1
    • oldkimmer
      19,352
      6506
      Nov 11, 2006
      Local Time:
      6:28 AM
      Maybe a cooler line? Kim
      • Like Like x 1
      • Cope
        4,976
        6419
        Oct 20, 2009
        San Jose, Ca.
        Local Time:
        6:28 AM
        It has a square pan.
        Is there any identity aspects i should be looking for?
      • Ddaddy
        Ddaddy I'm changing the World... one pixel at a time! FABO Gold Member
        23,123
        30844
        Nov 7, 2015
        SW of Philly PA
        Local Time:
        7:28 AM
        It either the 42RH and 46RH transmission. Since it is a 4x4 it is likely the 46RH.
      • oldkimmer
        19,352
        6506
        Nov 11, 2006
        Local Time:
        6:28 AM
        Is it a 4.7 motor?
      • Ddaddy
        23,123
        30844
        Nov 7, 2015
        SW of Philly PA
        Local Time:
        7:28 AM
        They had a factory TSB for failure of the transmission cooling lines causing massive fluid dump.
        • Thanks! Thanks! x 1
        • Cope
          4,976
          6419
          Oct 20, 2009
          San Jose, Ca.
          Local Time:
          6:28 AM
          360 Ci.
        • oldkimmer
          19,352
          6506
          Nov 11, 2006
          Local Time:
          6:28 AM
          So then it’s what Ddaddy said. Kim
        • Tooljunkie
          Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
          18,687
          19908
          Jul 22, 2017
          Manitoba
          Local Time:
          6:28 AM
          94 would most likely be a 360 magnum.
          My 94 has a 360. But its a stickshift.
          Had it about 3 years,still havent done anything with it. Runs nice and drives well. My yard truck.
          I wouldnt tear it out until leak is pinpointed.
        • Moparman1806
          Moparman1806 Well-Known Member
          427
          200
          Jul 14, 2014
          Central NC
          Local Time:
          7:28 AM
          Be especially careful with taking the overdrive apart. It needs a special tool that has to be used with a press for the overdrive spring.
          That coil spring will take your head off! I guarantee that the overdrive unit will be a mess with the metal in the pan.
          You will also need the special spline tool to align overdrive unit for reassembly.
        • j par
          j par Well-hung Member
          27,900
          15323
          Jul 2, 2014
          Portland Oregon
          Local Time:
          4:28 AM
          The big question here is it a 2500 or 1500? the 2500s had the bigger axles in the bigger transmission but not the massive transmission that the later diesels and V tens got..
        • 1994redram
          1994redram FABO Gold Member FABO Gold Member
          1,304
          722
          May 9, 2012
          Oklahoma
          Local Time:
          6:28 AM
          The over drive is lethal when taking it apart. I found that out and luckily didn't get hurt.
          It will be an A500/42rh which replaced the 904. Or a A518/46rh which replaced the 727. You can tell by looking the pan, the pans have the same bolt pattern as the old 3 speeds they replaced.
        • Cope
          4,976
          6419
          Oct 20, 2009
          San Jose, Ca.
          Local Time:
          6:28 AM
          It has no badging. So im thinking its a 1500?
          We got the truck for 400 bucks and tossed most of it in the scrap bin. The only part i haven't upgraded or fixed is the trans.
          Special tools... dammit.. got a part number for those or a place that wont charge an arm and a leg?
        • Moparman1806
          427
          200
          Jul 14, 2014
          Central NC
          Local Time:
          7:28 AM
          I will dig mine out to find the Miller numbers, and get back to you
          • Like Like x 1
          • 318willrun
            318willrun Utube channel 318willrun
            17,280
            19475
            Sep 13, 2013
            I'm here
            Local Time:
            6:28 AM
            5 lug rims 1500. 8 lug 2500
            • Like Like x 1
            • Moparman1806
              427
              200
              Jul 14, 2014
              Central NC
              Local Time:
              7:28 AM
              • Like Like x 2
              • Cope
                4,976
                6419
                Oct 20, 2009
                San Jose, Ca.
                Local Time:
                6:28 AM
                I want to say its a front 44 and a rear 60 but i cant remember and im not at the shop.
                How deep can i go into the trans before it lets loose and trys to kill me?
              • Moparman1806
                427
                200
                Jul 14, 2014
                Central NC
                Local Time:
                7:28 AM
                You can remove the overdrive case from the trans, it is when disassembling the overdrive that the danger comes into play. The rest of the trans is basically a 727 or 904 in the case of a v6
              • Cope
                4,976
                6419
                Oct 20, 2009
                San Jose, Ca.
                Local Time:
                6:28 AM
                The engine is a V8.
              • Moparman1806
                427
                200
                Jul 14, 2014
                Central NC
                Local Time:
                7:28 AM
                The trans will be a 46rh or A518- both the same, just renamed
                • Like Like x 1
                • SIX225
                  SIX225 Well-Known Member
                  144
                  71
                  Jan 31, 2016
                  Illinois
                  Local Time:
                  6:28 AM
                  Thought I read somewhere that there was something special about the gasket between the transmission and overdrive. Something about it acting like a shim and not just a seal.
                • oldkimmer
                  19,352
                  6506
                  Nov 11, 2006
                  Local Time:
                  6:28 AM
                  There is a shim between the od and the case
                • MOPAROFFICIAL
                  MOPAROFFICIAL Well-Known Member
                  7,970
                  7192
                  Jun 1, 2016
                  Beach
                  Local Time:
                  4:28 AM
                  Make sure to remove the check valve in the cooler lines, they clog and kill the transmission.
                  Do all the updates, turn up the psi, replace manual valve for full flow version that keeps the converter flowing in all
