A body inner fenders different after 1974?
Mopar Body and Trim
  1. mopars4life
    mopars4life Well-Known Member
    224
    30
    Oct 22, 2008
    Northern VA
    Local Time:
    12:49 PM
    I need a set for a project and noticed the aftermarket ones say 67-74 for the complete ones. Have a friend who has a 75 valiant he is parting but I need them for a 73 Duster. Anyone know if they are in fact different after 1974? Thanks
  2. zkx14
    zkx14 Duster De-ruster FABO Gold Member
    24,111
    17749
    Dec 23, 2012
    South Central PA
    Local Time:
    12:49 PM
    I don't think there is any difference other than maybe where some stuff was mounted. So may have some holes in the wrong place. From building my 75 I can tell you some places just don't list ANYTHING after 74. Even though the parts they are selling fit 75 and 76.
  3. mopars4life
    224
    30
    Oct 22, 2008
    Northern VA
    Local Time:
    12:49 PM
    Yes was hoping that was the case but wanted to tap all the expertise on the forum.
  4. zkx14
    24,111
    17749
    Dec 23, 2012
    South Central PA
    Local Time:
    12:49 PM
    I know the firewall changed quite a bit for diff years and AC or not.. I think you will be OK, but I'd probably get some good pics for comparison before cutting. Only structural change I know from 73 to 75 was the brace from the flange between firewall and cowl to the fenders. The back flange was widened for the U nut, but don't think they changed anything at the front except the bolt itself I believe is a larger washer. Probably wouldnt matter anyway.
  5. Dartnut
    Dartnut Don't hate me because i'm beautiful
    10,704
    2992
    Apr 19, 2007
    Southern Alberta
    Local Time:
    10:49 AM
    The inner fenders are the same except for some other holes that would be easy to fix as previously mentioned.
    The '72 and older ones are different on primarily the passenger side where they don't have the indent near the front for the radiator overflow bottle.
    '67 to '76 will physically interchange, but are different in a few ways..........
    • Like Like x 1
    • Agree Agree x 1
    • HemiSSDart
      HemiSSDart Dartus Interuptus
      1,296
      882
      Feb 20, 2013
      Illinoisy
      Local Time:
      12:49 PM
      They all fit but are in two distinct groups, 67-71 and 72-76 because of the passenger charcoal canister area. Sometime in the late 71 timeframe they changed.
      • Agree Agree x 2
      • Like Like x 1
      • sireland67
        sireland67 Well-Known Member
        8,934
        3090
        Oct 27, 2010
        WV
        Local Time:
        12:49 PM
        I have 75 fenders on my 73, small issues like trim holes etc.
      • Cuda Al
        Cuda Al Well-Known Member
        1,001
        1077
        Oct 21, 2007
        Lompoc, CA
        Local Time:
        9:49 AM
        I had a 74 parts car and a friend needed a right side inner fender for his 68, not even close, not just mounting holes.
        Will they work, probably, is it correct? Different stamping.
        Alan
      • 72bluNblu
        72bluNblu FABO Gold Member FABO Gold Member
        10,462
        4909
        Nov 28, 2008
        NorCal
        Local Time:
        9:49 AM
        This.
        They’ll interchange 67-76. If you want them to be “correct” you don’t want to mix the early and late versions, and year to year there are some different mounting hole locations.
        If you have a car with a charcoal canister and want to keep it you’ll need one with the indent on the passenger side. If you don’t have a charcoal canister it doesn’t matter which one you use beyond being able to tell the inner fender isn’t original to the car.
        • Agree Agree x 1
        • z_daddy
          z_daddy z_daddy
          247
          18
          Sep 21, 2008
          Naples, Fl
          Local Time:
          11:49 AM
        • z_daddy
          z_daddy z_daddy
          247
          18
          Sep 21, 2008
          Naples, Fl
          Local Time:
          11:49 AM
          Anybody know to eliminate inner fender wells ?? Thinking of cutting them out , my concern is shock tower , trying to lighten the car up
        • sireland67
          8,934
          3090
          Oct 27, 2010
          WV
          Local Time:
          12:49 PM
          They are semi structure for the fenders.
          I would not do it, unless you have a full cage with “J” bars on the front.
          Plus the inner fenders do not weigh much.
          • Agree Agree x 2
          • 72bluNblu
            10,462
            4909
            Nov 28, 2008
            NorCal
            Local Time:
            9:49 AM
            So on the stock chassis, if you remove the inner fenders you’re removing the only thing that triangulates the front frame rails and ties them to the firewall. They’re also the only thing that supports the shock mounts.
            Unless you have a full cage that’s a terrible, terrible idea. Even with the inner fenders in place there’s still a significant amount of flex in the front half of the chassis.
            • Agree Agree x 1
            • mopars4life
              224
              30
              Oct 22, 2008
              Northern VA
              Local Time:
              12:49 PM
              Thanks for all who provided the info on the difference with the inner fenders. I will see if I can find a used set for the correct year. I wonder if the AMD ones are patterned after the 72 and up since they only have one type of inner fender that they are selling.
            • Dartnut
              10,704
              2992
              Apr 19, 2007
              Southern Alberta
              Local Time:
              10:49 AM
              The AMD ones are patterned to be a direct fit for '71 and older a-Bodies.
            • 72bluNblu
              10,462
              4909
              Nov 28, 2008
              NorCal
              Local Time:
              9:49 AM
              That’s kind of a drag for anyone with a charcoal canister car. The inners with the indent for the charcoal canister fit the earlier cars fine. But if you have a car with a charcoal canister there’s no where to mount it easily if you use inner fenders without the indent. Guess it’s all about the guys with 70/71 cars looking “correct” :rolleyes:
            • zkx14
              24,111
              17749
              Dec 23, 2012
              South Central PA
              Local Time:
              12:49 PM
              You asked about using 75's in a 73. I saw nothing here to say you couldn't use them...
            • mopars4life
              224
              30
              Oct 22, 2008
              Northern VA
              Local Time:
              12:49 PM
            • mopars4life
              224
              30
              Oct 22, 2008
              Northern VA
              Local Time:
              12:49 PM
              Yes I have several a bodies and was thinking about the early ones in that response that I will need to source since I only have leads or extra later ones 74 and up and need some for a 71 as well.......unless I want to buy the new ones.
            • jos51700
              jos51700 Well-Known Member
              5,224
              1914
              May 24, 2009
              Bel-Ray
              Local Time:
              11:49 AM
              Disconnect the brakes and discard them. The car will never ever seem as fast any other way.
