A Body Leaf Spring Sliders
BergmanAutoCraft
FABO Vendor
FABO Vendor
Hampstead, NC
A Body leaf spring sliders now available. Replace your weak offset shackles with our bolt in solution. If you have your springs moved in with a typical offset kit (1/2") you are leaving tire clearance on the table. Our slider kit offers a level of lateral stability never available with shackles.
Designed to replace offset shackles on A body offset spring hanger kits
Bolts in using original upper leaf spring bushing bracket hardware
No mods to body
Superior lateral stability
Allows for larger tires due to reduced spring deflection
Contains delrin bushings for long life
Smooth progressive spring movement
Quiet operation due to tight tolerances and high load sealed bearings
Same ride height as shackles
Link for purchase - https://bergmanautocraft.com/produc...BgK_bxXwJY6oYNgy_GHkpUst3phxV3rf6oEtMV_1rtVIR
are these able to be used as non-offset? I'm not seeing where the offset is built into these.
