2doorswinger
Ive got some parts kicking around still. This is what ive got left. Let me know what you might need. Located in Guelph, Ontario. Can ship anywhere. Pictures available upon request.
- (2) 1969 dart grills. Both arent perfect. One is painted matte black, other is original. $100 ea
- 1971 340 Hi-po exhaust manifolds (large hole) $350 for the pair
- Rebuilt and painted 8 3/4, new 3.23 gears, rebuilt clutch sure grip, 489 case, large yoke, bbp, 43 inch perch to perch $1,300
- 1969 dart tail light lenses. Both in good shape. $100 for the pair
- (2) A-904 trans. One is rebuilt with a shift kit in running condition. Other came out of a running car and not touched. Both come with shift levers and some kickdown linkage stuff and a crossmember. $350 for the shift kit transmission, $200 for the other running trans.
- Brand new unused Mcleod High performance clutch/pressure plate (rated to 500 hp. Part # MCL-75241) $300
- (2) 22 inch radiators for A-Body. Near perfect shape. $150 ea
- Power steering gear box and pitman arm. Came off a car with 15,000 original miles. Operates and turns flawlessly. $200
- 1968 Fender full light assembly. 2 yellow, one red. All wiring included and good shape. $100 for the set
- A body gas pedal. Primed, ready to paint. Perfect shape. $100
- 1969 dart 4 speed clutch rod with boot $60
- Brand new small block water pump $60
- 1967 to 1969 dart hood latch assembly. $100
- 1969 dart OEM Hood louvers. Driver quality. Comes with back plate and finned louver. $200 for a pair
- 1967 to 1969 dart rear bumper brackets $100
- 3 window cranks $30
- A body emergency brake assembly $150
- a body windshield wipers $60 a pair
- 1969 dart tail light bezels. Driver quality. $75 a pair
- a body headlight buckets. $50 a pair
- 1969 dart gas tank. Good shape. $50
