Ironmike
I've attached a pic of specs from 2 cams. 2 different companies. As you can see, they are damn near twins. Except for the lobe separation angle and intake centerline.
I was hoping someone could REALLY tell me how these 2 cams might be so different.
Which one has more overlap?
Which one would have a higher reversion tendency?
Which would build more cranking compression?
I never did quite get the LSA and ICL thing. At least how they would change the characteristics of the cam...
Given the choice of these two, which would you run?
