cidVicious
Junior Member
Hey Transmission Gurus,
I need a little help identifying a 727 TorqueFlite Transmission. I think the number stamped into the rail just above the pan on the drivers side is,
PK40 9538 5884 8211. The P could be a B and the 11th digit could be a "6 instead of an 8.
I found this document on the Web,
http://www.mymopar.com/downloads/transguide.pdf
But I can't seem to correlate any of the numbers above as they're all seven digit numbers. I found a couple other numbers cast into my bell housing that may help with ID. They are "3748102-7" and "4028101".
This transmission was backing up a 360 LA and came out of a 1975 Dodge Sportsman Motorhome. I assume this was the original transmission as it seemed to be unmolested.
Can anyone tell me what I have? Any known problems (other than linkage mods) using this in my A-body?
Thanks,
Thanks,
