A833 - Identification and HELP!!
Manual Transmission & Clutch Discussions
  1. SouthernDart
    SouthernDart Active Member
    29
    2
    Mar 23, 2016
    Ecuador
    Local Time:
    4:50 PM
    Hi Gents
    I had the gearbox "Checked out" during body work stage and "all looks good" was my response.
    Now that I finally got my RestoMod Electrical work done and ready to run for the first time since I picked up my project 2 years ago I have a nasty grinding sound in 1st and 2nd gear.
    First and foremost - I have these codes on the housing and was hoping I can get as much info as possible by decoding them.
    Secondly, can anyone (after decoding my gearbox) recommend a good quality Overhaul Kit and/or sourcce for Parts so I can rebuild it well?
    Many thanks in advance from waaay south of the Border. Here are some Pics of its current state and the previously mentioned codes.
    TJ
    • Like Like x 1
    • Mopar92
      Mopar92 Well-Known Member
      1,460
      281
      Dec 23, 2015
      Lewisburg tn
      Local Time:
      4:50 PM
    • oldmopardude
      oldmopardude Well-Known Member
      856
      155
      Jan 31, 2011
      omaha nebraska
      Local Time:
      4:50 PM
      The 8B followed by the six digit serial number implies it is a VIN for a 1968 transmission
      • Agree Agree x 2
      • Frnknsteen
        Frnknsteen Well-Known Member
        547
        338
        May 26, 2011
        Spencer, IN
        Local Time:
        5:50 PM
        Yep,... According to the calendar, it specifically is May 14th, 1971.
        As far as a rebuild kit and source for parts, I would go straight to Brewers performance in Ohio. They have a ton of information on their website and have been very helpful in the past. (Link below). Click on the "Before you order" tab and there is a ton of information to help identify exactly what you have
        Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
      • oldmopardude
        856
        155
        Jan 31, 2011
        omaha nebraska
        Local Time:
        4:50 PM
        That definitely creates a puzzle IMHO, why is there a set of numbers identical to a 68 VIN?
        very curious. Original to the car?
      • 6pk2goDemon
        6pk2goDemon Mopar Mod Staff Member FABO Gold Member
        11,284
        2603
        Mar 1, 2008
        Arizona
        Local Time:
        3:50 PM
        Could the 3577 be the 357th day of 1967 ? That would make the trans correct for a 68....
        • Agree Agree x 1
        • Mopar92
          1,460
          281
          Dec 23, 2015
          Lewisburg tn
          Local Time:
          4:50 PM
          Call Brewers. He can tell you in 4 seconds.
        • HemiSSDart
          HemiSSDart Dartus Interuptus
          1,499
          1036
          Feb 20, 2013
          Illinoisy
          Local Time:
          5:50 PM
          • Agree Agree x 1
          • oldmopardude
            856
            155
            Jan 31, 2011
            omaha nebraska
            Local Time:
            4:50 PM
            at the bottom of my My 10,000 day calendar in the mopar book it says that the number
            seen does not apply to 1967.
          • Frnknsteen
            547
            338
            May 26, 2011
            Spencer, IN
            Local Time:
            5:50 PM
            Per Brewer's Performance page:
            Beginning with the 1968 model year (July 1, 1967), the main case has a small (3" by 7/8") raised, machined rectangular pad on the passenger side of the transmission, just above the casting number. Along with the vehicle's serial number stamped onto it, this pad will have a second line beginning with "PP833" followed by a 4-digit (10,000 day calendar) date code, such as "2264" (10-9-67) or "3055" (12-08-69) and sequential assembly number (405) for that day (pictured).
          • 6pk2goDemon
            11,284
            2603
            Mar 1, 2008
            Arizona
            Local Time:
            3:50 PM
            The OP is in Ecuador, South America so stampings may be different....?
            • Agree Agree x 1
            • Frnknsteen
              547
              338
              May 26, 2011
              Spencer, IN
              Local Time:
              5:50 PM
              The only thing that I could think of to explain would be this,.... What if the transmission was replaced sometime in late 1971 - early 1972 as a factory warranty replacement. I have read in other threads that some dealers stamped the VIN into the replacement part when doing the warranty work. Others said they didn't do that, but in the thread I was reading, someone said their relative worked for a Mopar dealership and said that they DID do that on warranty replacements.
              I don't know what the factory warranty was back then, but even if it wasn't a warranty issue, maybe it was a replacement transmission that was built in May of 71, and was stamped with the 1968 serial number when it was installed by the dealer.
              That or someone replaced it at some point and wanted to make it look like it the numbers matching original (and didn't know how to decode the manufacture date).
              Whatever someone wants to believe......
            • Frnknsteen
              547
              338
              May 26, 2011
              Spencer, IN
              Local Time:
              5:50 PM
            • oldmopardude
              856
              155
              Jan 31, 2011
              omaha nebraska
              Local Time:
              4:50 PM
              it may help to provide the casting number on the case and tail shaft housing. The vin appears to be gang stamped, which dealers had access to. The question is where did the car come from? I don't believe there was a Vin requirement for vehicles not built to U.S. specs. Anyway, the two sets of numbers appear to contradict each other if the car was in the U.S. If it were me, I would disassemble the unit and take pictures so the tranny guys up here can determine what it really is.
            • TrailBeast
              TrailBeast AKA Mopars4us on Youtube
              21,450
              9097
              Mar 11, 2011
              Arizona
              Local Time:
              3:50 PM
              Probably just the input shaft bearing anyway if it only seems to do it in first and second. (about the easiest one to get to):D
            • SouthernDart
              29
              2
              Mar 23, 2016
              Ecuador
              Local Time:
              4:50 PM
              I'm going to say its not original to the car. I'll never really know.
              Car was Imported from the U.S. so stampings are per U.S. standards.
              Gonna open it up and check in the next few days... Thanks all!
            • Alaskan_TA
              Alaskan_TA Well-Known Member
              5,751
              4064
              Nov 12, 2004
              PA
              Local Time:
              5:50 PM
              8B can also be from a 1978 Hamtramck built car.
              Can you get a photo showing all the numbers on the pad in one photo?
              An overall shot of the whole transmission?
              Is the main case iron or aluminum?
            • SouthernDart
              29
              2
              Mar 23, 2016
              Ecuador
              Local Time:
              4:50 PM
              Here are all my pictures and I cannot answer as to the Case Material. But it appears to be aluminum from photos. I'll stop by shop tomorrow if I get a chance.
              From what I gather it looks like a '77?
              Thanks for your help.
            • oldmopardude
              856
              155
              Jan 31, 2011
              omaha nebraska
              Local Time:
              4:50 PM
              Mystery solved. Pea brain here, I should have considered ten years newer. I own a 77' Model Cordoba and should have remembered that. ARGH. My head is stuck in the 60's all the time. 318 or 360? The bodies are totally different down there, so what is the exact model?
            • Alaskan_TA
              5,751
              4064
              Nov 12, 2004
              PA
              Local Time:
              5:50 PM
              No aluminum case in 1968, so yes, this gear box is from a 1978 model year car built at Hamtramck.
            • HemiSSDart
              1,499
              1036
              Feb 20, 2013
              Illinoisy
              Local Time:
              5:50 PM
              Of course, my head is buried in the 60's also, when people say 4-speed I always ASSume that is a cast iron case, not an aluminum case overdrive trans...
            • SouthernDart
              29
              2
              Mar 23, 2016
              Ecuador
              Local Time:
              4:50 PM
              Aluminum Case and 318.
            • SouthernDart
              29
              2
              Mar 23, 2016
              Ecuador
              Local Time:
              4:50 PM
              Any chance we can figure out the Gear Sets and confirm its an OD?
            • crackedback
              crackedback FABO Gold Member FABO Gold Member
              18,780
              3100
              Aug 7, 2005
              92201
              Local Time:
              2:50 PM
              The shift rods don't look like they are on the correct arms either. Reverse rod on 1/2 arm now
              The forward shift arm should be up on a later model OD style transmission.
              Put it in each gear and turn input shaft, count number of times input turns to 1 rev of output.
            • SouthernDart
              29
              2
              Mar 23, 2016
              Ecuador
              Local Time:
              4:50 PM
              Very observant! That pic was some time ago, I figured out that the shifting linkage was all messed up before dropping the Gearbox in the car. ;)
