A833 tranny, bellhousing hooker headers mech rockers kyb pwr brakes
1972orangebeast
Newark, Ohio
-earlier a833 cast housing, good tranny needs new side case gasket leaks a little. $400 pick up
-Pre 71 10.5 bell housing, it fits a body and early a833 been powder coated, rear main leaked over it but will clean up nice no chipping of the powder coat, plus fork pivot, and ball stud bracket $150
-Mechanical 340 rockers off a 69 motor, great shape have shafts and all spacers and rockers $200 plus ride
-Hooker Headers cermic coated, good shape bottoms are dented a lil from road (like they all do) cermic is pretty good shape still. $100
-KYB shocks with around 3000 miles on them, good condition prob need repainted due to trying to clean one with a little bit of brake cleaner and ate some of the paint :oops: $50
-Everything for power brake conversion, booster and master cylinder and brackets, pedal rod. Master cylinder is for front disc and rear drum. $75
-Will have a whole 73 kframe for sale with disc set up and proportioning valve end of February also if you want whole set up ill make a deal and possibly deliever if you in route of my trip. between Florida and Ohio.
Im located in Newark, Ohio 43055 will make deals on multiple parts and shipping
Is the bell housing for a small block or big block?
Might be interested in the K-frame as well.
