[WANTED] A833od 3/4 shift rod
Just lenghten the rod you have.
I done it for my od, and it worked fine.
If you do it correctly you will be able to use the same rod on a od and standard 4-speed.
I can take a picture of what I did, because my shifter is out of the car right now.
I just heated and bent my non overdrive shift rod to work for the overdrive. Worked just fine saved me time and money. I can always put it back the way it was.
