thermotodd
Member
Hey all,
I just finished swapping an automatic for a freshly rebuilt aluminum case A833OD into my 1969 Barracuda, and while it works great, it has started to leak gear oil from the bottom of the case where the reverse gear shift rod attaches. I’ve read that this is a common A833 problem (possible I overfilled it) and that on the original iron case 4-speeds it’s a real pain to get to the o-ring, but also that it might be significantly easier on a newer aluminum and that it can be done with the transmission in the car. Is that true, or should I prepare myself to pull it back out and disassemble it? For reference, the transmission came out of an early eighties Volare and I filled it with the PennGrade 80W90 that Brewer’s recommended.
