Slantsix64
Hey guys so on the freeway last night started smelling some trans fluid. Sure enough it was leaking from the front seal. Now the car shifts perfect , oils not burnt or smells, it has a trans cooler, and a Shift kit.
It leaks when its parked and running its not leaking on start up but once i start driving when its parked i believe its all the trans oil left in the front case leaking through the trans shield.
First Question, can it just be the front seal? why i ask is because a long time i changed a front seal in my 71 darts 904 because it was pissing fluid. And it didnt fix the issue it had a internal pump problem.
Second question i had a shift kit installed in this transmission can i just swap it into another running one? thanks guys!
