[WANTED] Abody a833 transmission
Robin House
Ontario
Rating - 0%
0   0   0
hi guys I’m looking for an a833 4 speed with O/D. I have one now in great shape but it has the long tail housing which is for B&E body’s. It would be great to find some one who has one for an Abody but needs B or E body. We could swap.
I would also consider selling the one I have.
I live in Canada but would be willing to cross the border to pick up
I have a 833A but do not need the B tranny. do you have any parts for my A body cuda?
I am in PA near lake erie. I just dropped a 360/727 into my cuda, pulled from a 85 dodge 15 passenger (one ton) van. all you gotta do is cut the driveshaft down and re-weld it!
To put the a833 that I have in my dart? Won’t the shift be in the wrong spot?
The OD was available several different ways;
C.I. case or aluminum, small MS or large, How much power are you thinking of putting thru it?
I could probably build you one from spare parts. Or even convert yours.
You sure you want an OD box?
You can make your long-tail work if you wanted to, I have one in my 68 Barracuda. You can fabricate a plate to put the shifter anywhere you want to. I moved mine back between the buckets and made new longer stiffer shiftrods. No more missed shifts.
Im pretty sure you could convert it to a short tail if you could find the parts, but it would be easier to make a driveshaft to fit.
How did you move the plate for the shifter? Did u just weld a new one to the tail?
Guys, this is a classified ad. Conversation and discussion is not allowed. If you need to figure out how to do conversions etc., start a thread in the proper forum or discuss it through private conversation.
Thanx
Wow this will help great. Takes all the guess work out. So for the rods, i’m Guessing they are the normal rods used for the A-Body?
PM sent.
