Abody ebody linkage
340Clone
Member
Johnstown, Colorado
Do small block 727s Abodys have the same floor shift linkage as a big block ebody? Can't get the shift indicator to line up correctly.
Thanks in advance.
It's not even close.
I've seen pics of them made to work, but it takes more than "a bit" of fabbing and modding to do it.
If your putting in a big block 727 in where a sb 727 was then yes the car linkage will work in either body style. It’s the lever on the tranny that may be different then just swap the levers from one trans to the other trans. I have a Cuda slap stick in my race car. Kim
I did some investigating on Year One and they have different part numbers, so pretty sure if I change it everything should line up. Thanks everyone!
Nope. Currently using ebody linkage, works but indicator on console does not line up. Want correct abody linkage for 340 and 727. No mix or match, just correct linkage for abody. I have posted on WANT TO BUY for a correct set.
