Advice on Edelbrock 1404 CARB @ 6700 FT Altitude
Discussion in 'Fuel and Air Systems' started by SouthernDart, May 14, 2018.
  1. SouthernDart
    SouthernDart Active Member
    29
    2
    Mar 23, 2016
    Ecuador
    Local Time:
    1:04 PM
    Hi Guys:
    Resto Mod Project is out and about, first few hundred miles being put on it waaay south of the border in the Andes Mountains of Ecuador.
    Being just under 7K Feet altitude is always a carburetor issue and Edelbrock will only provide Tech Support over the phone....(unreal)
    Anyway Gents - if any of you can provide some insight into how to best setup (Daily Driver RestoMod) - I'd greatly appreciate it.
    Here's some starting info:
    318 with 1404 Edelbrock Carburetor + Edelbrock 2176 Performer Intake.
    I have the Edelbrock 1486 Carb Tuning Kit - so I can use anything from it.
    Many thanks and and/all advice or Setups welcome.
    TJ
  2. General Disarray
    General Disarray Well-Known Member
    164
    117
    May 4, 2018
    South Park
    Local Time:
    12:04 PM
    Most people are happy to talk with "live" tech support.
    Did you read the carb manual? If you don't have it, here's the link:
    http://www.edelbrock.com/automotive/misc/tech-center/dl/carb-owners-manual.pdf
    Page 9, High Altitude. Read the manual, follow directions, should not be too complicated. These carbs are generally easy to tune.
    Looks like the 1486 kit should have what you need.
    Good luck.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • Oldschoolcuda
      Oldschoolcuda Early-A Body Nerd FABO Gold Member
      4,317
      2687
      Mar 24, 2008
      Suffolk,Virginia
      View My Photos
      Local Time:
      2:04 PM
      You want to be 2% leaner for every 1500 feet of elevation.
      Number 24 on page 18 of the edelbrock tuning guide is good starting point for you. Requires just a rod change. If you do not have access to a guide replace stock rods with #1440 in your kit(060 x 057).
      Will be 8% lean after this.
      • SouthernDart
        29
        2
        Mar 23, 2016
        Ecuador
        Local Time:
        1:04 PM
        Thanks! But I found number 24 on page 18 for a different carb..
        Think #13 is a starting point.
      • Oldschoolcuda
        4,317
        2687
        Mar 24, 2008
        Suffolk,Virginia
        View My Photos
        Local Time:
        2:04 PM
        Was thinking power mode not cruise so 13 will be a better starting point.
        Good luck
