Air cleaner chocking out engine
Slant 6 Engines
  1. Brian Bearor
    Brian Bearor Well-Known Member
    48
    4
    May 1, 2021
    New York
    Local Time:
    9:32 AM
    The air cleaner is chocking out the engine.
    I saw I am missing the ring that goes between the carb and the air cleaner. See the pic.
    Will this solve the problem?
    Thanks for the insight.
  2. dadsbee
    dadsbee FABO Gold Member FABO Gold Member
    1,363
    3058
    Nov 25, 2020
    Penetang, Ontario
    Local Time:
    9:32 AM
    All that is is a flat rubber seal. Won't change your choking issue. Nor does it make much sense unless the filter is totally clogged or the filter assembly is jamming something on the carb linkages.
    • Agree Agree x 3
    • Brian Bearor
      48
      4
      May 1, 2021
      New York
      Local Time:
      9:32 AM
      Odd. New filter too.
    • tonysrt
      tonysrt FABO Gold Member FABO Gold Member
      1,009
      526
      Dec 25, 2016
      Northport, NY
      Local Time:
      9:32 AM
      That is not your problem. Make sure the air cleaner is not restricting the choke plate from opening completely. That gasket just prevents non filtered air from leaking in.
      • Like Like x 2
      • Agree Agree x 1
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        81,584
        61242
        Jun 7, 2010
        Georgia
        Local Time:
        9:32 AM
        What do you base your hypothesis on?
      • Brian Bearor
        48
        4
        May 1, 2021
        New York
        Local Time:
        9:32 AM
        Of choking out the engine? If you were asking me.
        The plugs were fouling and when I took off the air cleaner it ran much better and the plugs are burning correctly. Ran with it off.
      • A56
        A56 MoPar Affliction
        5,834
        15867
        Jun 24, 2014
        White Oak, N.C.
        Local Time:
        8:32 AM
        A few pictures of your air cleaner assembly installed and removed would help much more than what you posted.
        • Like Like x 1
        • pishta
          pishta I know I'm right....
          21,833
          11260
          Oct 13, 2004
          Tustin, CA
          Local Time:
          6:32 AM
          your air cleaner housing may have been hitting a choke linkage, causing the choke not to fully open, causing a rich condition and a terrible restriction while underway.
          • Like Like x 3
          • Agree Agree x 2
          • harrisonm
            harrisonm Well-Known Member
            3,853
            4345
            Jan 16, 2005
            Topeka, KS
            Local Time:
            2:32 PM
            Definitely sounds like the carb is in (or very near to) full choke and staying there. Like @pishta said, look carefully for something that is keeping the choke from kicking off.
            • Like Like x 1
            • Perseus
              Perseus '65 Dart slantsix
              72
              30
              Aug 8, 2019
              Cape Coral
              Local Time:
              9:32 AM
              Love the pic. The downdraft tube keeps you moving. Nice, basic shot for reference.
              • Like Like x 1
              • Thanks! Thanks! x 1
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                52,500
                21653
                Oct 14, 2010
                Idaho
                Local Time:
                6:32 AM
                Is it possible the filter element is TOO SHORT
                Also, "back in the day" when I owned the 440-6 RR I got the air filter wet--and dried out after the rain. turns out air filters DON'T LIKE that!!! They don't flow much air!!
                • Agree Agree x 4
                • Like Like x 1
                • brian6pac
                  brian6pac Well-Known Member
                  5,668
                  4028
                  Nov 15, 2016
                  N.E.Ohio
                  Local Time:
                  9:32 AM
                  The O.D. of you filter to close to the I.D. of the lid ?
                  • Like Like x 1
                  • Agree Agree x 1
                  • tonysrt
                    1,009
                    526
                    Dec 25, 2016
                    Northport, NY
                    Local Time:
                    9:32 AM
                    The air cleaner top looks awful close to choke linkage. Maybe that gasket that is missing might keep the lid off the choke linkage, as long it is about 1/4" thick.
                    • Like Like x 1
                    • RustyRatRod
                      81,584
                      61242
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      9:32 AM
                      Yes they are. That's how they're designed. There's only like 1/8" of gap all the way around. But it's enough to flow more than what a stock one barrel slant needs.
                      • Like Like x 1
