Air cleaner options 65 barracuda 2 barrel
Bud27
West LA
It has the stock 2 barrel Carter carb. Looking for cold air intake or filter adapter for bigger filter .
any input would be great and thanks in advance.
just my idea. i dont like cold air intake. for daily drivers. it lets in to much trash , leaves ect. the HP gain is not worth the trouble.
Doesn't the air cleaner have a snorkel on it? Run something like heating ducting from the snorkel to the front and instant cold air system.
No it has a weird clamp under the air cleaner base . I'll post pics in the am .
Is this the kind of air cleaner you have????
I believe 65 dartman was referring to adding flexible ductwork to the snorkel.....
It has a small Edelbrock air cleaner using the original base .
That's why you have to use the air cleaner base with the aftermarket top. The carb doesn't have provisions to run a regular air cleaner that uses a wing nut to secure the air cleaner to the carb.
would the larger aircleaner for a 318 2bbl fit - I think it has the same throat size as a 1bbl with a bigger filter element and they are a dime a dozen
