73SwingerBuild
Does anybody have a 1/4", 3/8", and/or 1/2" carb-to-air cleaner spacer laying around? I believe the diameter would need to be ~5-1/8". Needs to fit a Holley 3310 series carb.
My Spectre Performance drop-base air cleaner interferes with my jegs throttle linkage return springs. Yes, I know that putting a spacer will eliminate some of the clearance gained from a drop base air cleaner, but it's a 1-3/4" drop and should still leave enough room for the 3" filter element (fingers crossed).
Let me know what you have or how any of you solved the issue.
Thanks FABO.
-Mike
Thanks FABO.
-Mike
