Air Compressor choice
Discussion in 'Shop, Garage and Tools' started by scott657, Mar 23, 2018.
  1. scott657
    scott657 Well-Known Member
    254
    73
    Dec 26, 2016
    Lancaster, Ca
    Local Time:
    1:39 PM
    Ive had a Craftsman 33 Gallon 6 HP compressor (oil less)for about 18 years and has served me well.
    It has just taken(given) its last breath. I'm looking to replace it with something comparable. My requirements are running air tools etc. I will probably never paint with it. It looks like sears doesn't have that model any more. I would like an American made product if possible
    120 volt and portable Id like to keep it under $500.00 if possible. Just looking for suggestions.
    I wont buy a compressor from HF.
    • Agree Agree x 2
    • RustyRatRod
      RustyRatRod Just another dumbass. Technical Editor
      46,180
      10539
      Jun 7, 2010
      Georgia
      View My Photos
      Local Time:
      4:39 PM
      • Like Like x 2
      • Agree Agree x 1
      • brian6pac
        brian6pac Well-Known Member
        2,827
        1374
        Nov 15, 2016
        N.E.Ohio
        Local Time:
        4:39 PM
        You get what you pay for. I bought a IR T30 5hp 80 gal 30 years ago still purrs like a kitten the pump runs slow 1750 rpm motor, makes 180 psi. My air tools work better, impacts take the bolt off instead of beating it for 30 seconds or longer and pounding the hammers and anvil inside the impact. I could go on and on why it's better but most people don't care.
        • Agree Agree x 2
        • Marcohotrod
          Marcohotrod Well-Known Member
          2,057
          437
          Mar 21, 2015
          Massachusetts
          Local Time:
          4:39 PM
          If u have the space , more gallons = better
          • Agree Agree x 3
          • Demonic
            Demonic Well-Known Member
            254
            97
            Mar 21, 2015
            Maryland
            Local Time:
            4:39 PM
            It's like building a garage. You'll use all of it eventually. I bought a used Champion, 80 gal 5 hp. Put new valves in it and it is great.
            Look on CL for lightly used commercial models. Better than the newer oil-less junk.
            • Agree Agree x 2
            • Like Like x 1
            • Chained_360
              Chained_360 FABO Gold Member FABO Gold Member
              367
              87
              Nov 11, 2015
              Anchorage, Alaska
              Local Time:
              12:39 PM
              We had a T30 at our shop that just let go. The motor decided it didn't like not being on fire. It was a great compressor, I don't know how long the shop has had it but it was a nice unit for sure.
            • jamesdart
              jamesdart Well-Known Member
              1,538
              38
              May 6, 2007
              Local Time:
              3:39 PM
              I also bought a used 5hp t30.
            • RAVano
              RAVano Active Member
              43
              22
              Mar 27, 2018
              Ct
              Local Time:
              4:39 PM
              I had the same exact Craftsman compressor and recently got rid of it for a Harbor Freight 29 gallon 2 HP compressor. For $329 with a coupon you cant go wrong. I'm very happy with it.
            • myduster360
              myduster360 FABO Gold Member FABO Gold Member
              413
              337
              Oct 8, 2009
              Central IL
              Local Time:
              3:39 PM
              I had the exact same Craftsman for about just as long before the piston blew. It was easily fixed for ~$30 for a new piston kit and then sold it.
              While researching, i found 6-8 different brands of the 60gal suspiciously had the same "3.7hp" spec'd motor. If you compare the design of the compressor and plumbing, they're dead nuts copies. The house brands of lowes, menards, Home depot, Dewalt and YES even HF, appeared to be the EXACT same model. Even the $600 IR at the farm store was indistinguishable in every way but the color and name on the tank.
              I replaced my Craftsman anyway with a 230v 60gal Sanborn from Menards. They had the best deal of all the clones.
            • 67Dart273
              67Dart273 Well-Known Member
              37,524
              5228
              Oct 14, 2010
              Idaho
              View My Photos
              Local Time:
              1:39 PM
              Guys, guys, GUYS!!! "Gallons" don't mean squat. The airflow, preferably rated at 90psi is what you "want to hear." All "more gallons" does is let you run it for a bit 'o short time more before the thing pops on, and if the pump is teeny, it will "run out."
              AIRFLOW is what you want. FLOW, cfm
              • Agree Agree x 4
              • TheGrateRonzini
                TheGrateRonzini FABO Gold Member FABO Gold Member
                220
                126
                Oct 25, 2017
                Western New York
                Local Time:
                4:39 PM
                FC721A0A-7963-4658-B2E0-D0F3441F7FCF.png I just got this one. VERY pleased. I had a twin hotdog Rolair for nail guns and such and loved it. Prompted me to get the Rolair 60 when I needed my shop upgrade. I’m sure they have something smaller that would be close to what you want. I saw a 29 gal for 424$ on there. The Acmetools site was great too Lots of compressors and you can check all the flow ratings for comparison
              • RAVano
                43
                22
                Mar 27, 2018
                Ct
                Local Time:
                4:39 PM
                That was the deciding factor on mine. It had a bit more CFM than the other ones I looked at.
              • Krooser
                Krooser Reform School Graduate
                780
                410
                Jul 19, 2015
                Land of Cheese
                Local Time:
                3:39 PM
                Surprisingly the 5 hp 80 gallon Horrible Freight compressors are made in the US by the same outfit that makes Bel-Aire and C-Air outfits.
                I've had a Bel-Aire for 18 years. The do use an import compressor but the ones I've seen have US motors and tanks. Mine does not have any ID as to country of origin.
                I had a motor die and bought a rebuilt from my local motor shop.... maybe 10 years ago. Now that motor quit but I believe it just needs a capacitor so I ordered a start and a run capacitor for it. Less than $25 on Amazon.
                Film at 11.
              • pauly
                pauly MOPAR or no car! FABO Gold Member
                1,473
                213
                Nov 1, 2012
                Holton, Michigan
                Local Time:
                3:39 PM
                Harbor Freight 5 hp, 60 gallon, 230V. US General. 3 years and no issues. $800.
              • Cuda Al
                Cuda Al Well-Known Member
                468
                289
                Oct 21, 2007
                Lompoc, CA
                Local Time:
                1:39 PM
                7 years and running on mine, and that was with 2 years of heavy use doing bodywork.
                Alan
              • sireland67
                sireland67 Well-Known Member
                7,362
                1298
                Oct 27, 2010
                WV
                Local Time:
                4:39 PM
                When my old compressor came apart, I used the tank and put it in series, with the new compressor, it allows for more reserve capacity.
              • 1969383S
                1969383S FABO Gold Member FABO Gold Member
                3,569
                1095
                Jan 8, 2012
                Cumming, GA.
                View My Photos
                Local Time:
                4:39 PM
                Was fortunate enough to get a freebie 80 gallon IR to replace my 30 Craftsman that served me very good for many years. The IR is awesome but does require 30amp service. Put it outside in a pre-made shed and hardly hear it running. In fact unless the cutoff air valve is open it never runs till needed and then very quietly.
              • sireland67
                7,362
                1298
                Oct 27, 2010
                WV
                Local Time:
                4:39 PM
                I also have my compressor outside in one of those little plastic buildings.
              • Bill Crowell
                Bill Crowell Well-Known Member
                697
                185
                Oct 16, 2007
                Diamond Springs, CA
                Local Time:
                1:39 PM
                Have had a Campbell-Hausfeld 60-gallon vertical, 2-stage, 18 SCFM @90 psi compressor ever since the mid '90s and it has never given me any problem. However, I have no idea whether C-H still makes them with the same quality or not.
              • scott657
                254
                73
                Dec 26, 2016
                Lancaster, Ca
                Local Time:
                1:39 PM
                I went to 3 lowes in town, but got a big runaround on the compressor I wanted. I ended up at tractor supply and got their porter cable 30 Gal.
                Thus far it is meeting my requirements, its also quiet.
