AirGap under a stock hood
Mopar General Discussions
  1. 512Stroker
    512Stroker We are all here because we are not all there.
    3,131
    2477
    May 30, 2016
    Freedom, MO
    Local Time:
    11:59 AM
    I will be doing some engine upgrades this winter one of which is an Edelbrock AirGap intake.
    67 Barracuda, LA 340, Edelbrock 800 cfm carb, Edelbrock drop base 14 inch air cleaner.
    Will it all fit under the factory hood without any modifications?
    Thanks in advance
    Jim K
    • Like Like x 1
    • kursplat
      kursplat FABO Gold Member FABO Gold Member
      4,278
      3225
      Aug 24, 2010
      so cal
      Local Time:
      9:59 AM
      dang, i seem to remember another thread about the same thing a couple months ago...see if i can find it...
      • Thanks! Thanks! x 1
      • lenky1
        lenky1 Well-Known Member
        658
        310
        Jul 30, 2014
        illinois
        Local Time:
        11:59 AM
        I have a 71 340 duster with an airgap and basically the same setup. It fits but just barely
        • Like Like x 1
        • Agree Agree x 1
        • kursplat
          4,278
          3225
          Aug 24, 2010
          so cal
          Local Time:
          9:59 AM
          • Like Like x 1
          • 72bluNblu
            72bluNblu FABO Gold Member FABO Gold Member
            11,787
            6624
            Nov 28, 2008
            NorCal
            Local Time:
            9:59 AM
            I have a RPM air gap on the 340 in my Duster (demon clone with Dart hood). I run a Holley 750 double pumper with a 1" carb spacer and a 13" Mopar Performance air cleaner lid using a drop base from a Ford racing air cleaner with a 2.3" tall air filter element. I even run a small spacer under the air cleaner to clear my throttle linkage at WOT. Mancini sells a drop base now for the mopar performance air cleaners, but that wasn't available when I did mine.
            The Ford Racing air cleaner I stole the drop base from is advertised as a .625" drop.
            And here's a few pictures of the set up in the car. Pardon my dirt.
            • Like Like x 3
            • SGBARRACUDA
              SGBARRACUDA ROY FABO Gold Member
              21,537
              10038
              Dec 7, 2006
              PLANT CITY FL. and PERRY GA.
              Local Time:
              12:59 PM
              My 68 Barracuda 416 Has a air gap with a 1" spacer and a Holley 750 HP. Also has a 14"x3" air filter.
              • Like Like x 2
              • pishta
                pishta I know I'm right....
                21,449
                10830
                Oct 13, 2004
                Tustin, CA
                Local Time:
                9:59 AM
                I ran a 14" drop base air cleaner and a Holley strip Dominator, even with a Holley it fit. I saw the wing nut in my hood insulation.....65 A
                • Like Like x 1
                • Agree Agree x 1
                • harrisonm
                  harrisonm Well-Known Member
                  3,633
                  3940
                  Jan 16, 2005
                  Topeka, KS
                  Local Time:
                  5:59 PM
                  I have a 69 340 Barracuda with an Air Gap and a 750 Eddy. It does fit. I did go with an aftermarket low rise air cleaner (an Eddy one with base, 3"Element and top). I was concerned about clearance, so I went with a 2.5" filter element.
                  • Ironracer
                    Ironracer Gearhead
                    2,649
                    1843
                    May 8, 2020
                    Tampa Bay Florida
                    Local Time:
                    12:59 PM
                    Holley Strip Dom, with a 1" spacer ( since removed), 750 vac... plenty of clearance. Made a " cold air " unit ..
                    Design from FABO! (408demon, N-96, one of none) I hope I'm right on that. It's a 3 inch cake pan...does Not hit... only the open top element touches the hood skin...and that is getting " The Blade".. if you look at the frame, it actually Has, a radius ( kinda stamped, or Pushed in) looking indent.... like the engineer wanted room, for.... A big ass intake! I think You will have room! I couldn't get an offset center base, that was dropped. So it's a flat base, has 3" filter too
                    • Ironracer
                      Ironracer Gearhead
                      2,649
                      1843
                      May 8, 2020
                      Tampa Bay Florida
                      Local Time:
                      12:59 PM
                      Ps, that hood was butchered ( holes in it) when I got it, if you look Close, the frame of the hood has factory round indents, left and right, of hacked holes
