JRod01
Jesus is my Savior!
This is mostly an inquiry of a "what was it" scenario. Beginning at the end, my Duster needed a new battery. I was trying to get the car to start on the now replaced (agm style) battery and used a "jump start" feature from a charger since it wouldn't fire on its own. The car fires and everything seems normal until I try to start on it's own again and won't turn over. New (standard style) battery goes in. Turns over great but now won't start! Okay, getting fuel, check. Getting spark, no. Start diagnosing the MSD box and get that problem resolved. (Maybe went in to a safe/protect mode due to the jump box?) So here's the question: I am in the engine bay checking voltages and out of curiosity I check voltage at the charging post on the alternator. (It's a tuff stuff one wire.) Real quick: the battery is in the trunk and has a master disconnect. I have the elec. fuel pump off at this moment also. The cars ignition is in the run position while checking voltage. As soon as I touched the voltmeter lead to the charging post the starter motor engaged and bumped the engine over. I understand the charge cable and starter cable tie directly to the battery so I see how it can happen. But did the alt. somehow retain some kind of charge or perhaps re-magnetize the field? Needless to say the car and everything running just fine but was really curious as to why the checking of voltage at the alternator caused the starter to bump. Have a great weekend everyone!
