All small blocks share same crank ?
Small Block Mopar Engine
  1. str12-340
    str12-340 FABO Gold Member FABO Gold Member
    1,948
    1245
    Dec 26, 2012
    Vashon, WA
    Local Time:
    10:53 PM
    Something different to check if the car has been modified is if the angle of the driveshaft at the rear end and transmission is correct. Had an A-body friend who chased just such a problem for months and that was the fix (wedges between the axle locators and the springs got it straightened out). Don't know the correct angles off hand. IT increases with severity with speed not RPMs.
    • Agree Agree x 1
    • 66fyssh
      66fyssh Don't Stop Believin' FABO Gold Member
      6,365
      5924
      Jun 22, 2013
      Northwest GA
      Local Time:
      1:53 AM
    • pearljam724
      pearljam724 Well-Known Member
      435
      148
      Aug 29, 2019
      United States
      Local Time:
      1:53 AM
      I did that a couple months ago. Good suggestion. I shimmed it 2 degrees and it helped a lot. But, the smallest amount of humming in driveline remains at 70 mph. I’ve addressed everything but the balance of the drive shaft and tranny mount. But, tranny mount looks to be ok. Pretty sure at this point driveshaft needs balanced. Or driveshaft / yoke is slightly bent. Or rear end needs shimmed an additional 2 degrees. Since this thread was started. I found my engine mount bolts were loose as hell.,That didn’t help either. But, I tightened them and smallest amount of humming remains in driveline at 70.
