have a pair of aluminum valve covers that have a 1 inch id hole that pcv and breather gromets won't fit anyone know what is used in these holes both have the twist in oil filler caps also thanks
I do not run PCV valves on the race cars. I tap the
extra holes and plug them. I run just a single breather on
each cover. If you have more blow by than those can handle it
is time for a engine rebuild.
