Almost Perfect Block Okay to Use??
Small Block Mopar Engine
  1. 72DMag
    72DMag Well-Known Member
    854
    138
    Oct 21, 2019
    Pittsburgh
    Local Time:
    10:54 AM
    Received the 5.9 block back from the machine shop. I already the the pistons and rod here and assembled. machinist said the block just neded honed no need to bore it. Well he was almost right or maybe I'm wrong. All cylinders look great but there is one indented scratch on one cylinder and it does catch my finger nail. But it doesn't catch my finger nail all the time and I need to be at an angle for it to catch.
    Would this be an issue because the motor is going to see track use? Is there anything I can do to make sure it won't be a problem? I tried a ball hone on it and I'm pretty sure that did nothing. Maybe try a stone honing tool or something? I hate to bore it over because of this especially when it turned out with a super nice cross hatch!
    Pics are below you can see that it is a deep mark on the cylinder wall.
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    79,596
    58104
    Jun 7, 2010
    Georgia
    Local Time:
    10:54 AM
    5.8?
  3. pishta
    pishta I know I'm right....
    21,427
    10808
    Oct 13, 2004
    Tustin, CA
    Local Time:
    7:54 AM
    Run it. That's my vote. Doesn't look that bad, seen far worse on non smoker strong runners.
    • Agree Agree x 9
    • 72DMag
      854
      138
      Oct 21, 2019
      Pittsburgh
      Local Time:
      10:54 AM
      @RustyRatRod 5.9 sorry that was my typo and it's been corrected.
      @pishta I'm not too concerned if it smokes. More concerned of the moly rings catching it and creating an issue.
    • RustyRatRod
      79,596
      58104
      Jun 7, 2010
      Georgia
      Local Time:
      10:54 AM
      I didn't think that looked like a 351 Ford. lol
      • Thanks! Thanks! x 1
      • RustyRatRod
        79,596
        58104
        Jun 7, 2010
        Georgia
        Local Time:
        10:54 AM
        But I agree, run it. It's in one spot. Might be different if it was a long vertical gash.
        Somehow that didn't sound right.
        • Agree Agree x 3
        • Thanks! Thanks! x 2
        • 72DMag
          854
          138
          Oct 21, 2019
          Pittsburgh
          Local Time:
          10:54 AM
          • Agree Agree x 1
          • pishta
            21,427
            10808
            Oct 13, 2004
            Tustin, CA
            Local Time:
            7:54 AM
            If its a scratch, dress the high side with a stone. The ring wont catch on a divot...its an easy test to push the ring pack past it.
            • Agree Agree x 3
            • Like Like x 2
            • Phreakish
              Phreakish Well-Known Member
              1,432
              981
              May 28, 2015
              N. Idaho
              Local Time:
              7:54 AM
              If it's been honed over, shouldn't be any high spots, but may be a sharp edge.
              I agree, push a ring past it and see if you can feel it with the ring. Probably not. But I might also worry what created the divot. Must have been there before, I'd guess? Or was the engine damaged in any way?
            • Oldiron440
              Oldiron440 Well-Known Member
              716
              918
              Jan 12, 2019
              North central Iowa
              Local Time:
              9:54 AM
              Run it!
              • Agree Agree x 2
              • Bewy
                Bewy Well-Known Member
                1,312
                823
                Jan 1, 2021
                Australia
                Local Time:
                2:54 AM
                If it is high enough in the bore that the rings pass over it, I would be worried the end of the oil ring rail could catch on it. It has two rails to choose from...
              • George Jets
                George Jets 1967 Dart 2 Door FABO Gold Member
                5,634
                7726
                Jan 18, 2019
                Farmington MN
                Local Time:
                9:54 AM
                All of the high compression pressures are on the upper half of the cylinders. Much more critical up there.
                Run It . . .
                • Agree Agree x 2
                • Like Like x 1
                • JBurch
                  JBurch FABO Gold Member FABO Gold Member
                  1,953
                  1139
                  Oct 17, 2009
                  Owego, NY
                  Local Time:
                  10:54 AM
                  What color is the "scratch"? Looks like rust to me, hope it is not. That "scratch" could be a crack. I know it's odd; if it is a crack; that it is horizontal, they normally run vertical.
                  It's an idea, hope I'm wrong on my "guess", just one more opinion of the many you will receive here.
                • krazykuda
                  krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                  60,427
                  26590
                  Aug 20, 2007
                  Orland Park, IL
                  Local Time:
                  9:54 AM
                  You said long vertical gash... :D
                  • Like Like x 1
                  • Agree Agree x 1
                  • Mopar Sam
                    Mopar Sam Well Fed Member
                    1,502
                    2254
                    Jul 18, 2008
                    Indiana
                    Local Time:
                    10:54 AM
                    Run it! Worry about something else, like what's for supper.
                    • Agree Agree x 4
                    • Dartnut
                      Dartnut Don't hate me because i'm beautiful
                      11,770
                      4836
                      Apr 19, 2007
                      Southern Alberta
                      Local Time:
                      8:54 AM
                      X2
                      lol
                      • Like Like x 2
                      • Professor Fate
                        Professor Fate Push the button, Max...
                        2,494
                        3396
                        Jan 13, 2020
                        Wisconsin
                        Local Time:
                        9:54 AM
                        Which cylinder is it (hard for me to tell from the pics), and where is the "scratch" oriented? I'd run it and not worry about it *UNLESS* it's at the front of #1. If it is, be careful- it could be an indication that someone used too long of a timing cover bolt and cracked a cylinder wall.
                        • Agree Agree x 1
                        • Krooser
                          Krooser Building Chinese Free Engines since 1959...
                          3,360
                          2937
                          Jul 19, 2015
                          Central Wisconsin
                          Local Time:
                          9:54 AM
                          Run it...
                          • Agree Agree x 2
                          • Dave_J
                            Dave_J Well-Known Member
                            259
                            216
                            Nov 27, 2019
                            Auburn, WA
                            Local Time:
                            7:54 AM
                            I have seen this. And it was midway down the bore of #1.
                          • durango r/t
                            durango r/t New Member
                            3
                            1
                            May 4, 2021
                            florida
                            Local Time:
                            9:54 AM
                            Rebuilt the 5.9 in my durango r/t about 9-10 months ago along with the tranny and transfer case as the durango had 304,987 miles on it. Never been rebuilt and the cylinders were perfect,no ridge and full cross hatch top to bottom..The bearings had 2000 on them as my durango is a 2000.The tranny is why i rebuilt it,the bearing and rings looked good
                          • MOPAROFFICIAL
                            MOPAROFFICIAL FABO Gold Member FABO Gold Member
                            9,476
                            8831
                            Jun 1, 2016
                            Oceanside ca.
                            Local Time:
                            7:54 AM
                            Run it.
                            Seen worse.
                            Vertical as well, still ran it and no issue.
                            • Like Like x 1
                            • Agree Agree x 1
                            • mygasser
                              mygasser FABO Gold Member FABO Gold Member
                              1,299
                              923
                              Aug 17, 2010
                              faversham, kent. united kingdom
                              Local Time:
                              9:54 AM
                              and if the dog's gonna eat it before you get to cook it :rofl:
                              • Like Like x 1
