You may want to conduct a voltage drop study before attempting the Mad bypass, and correct the poor connections and conductors causing excessive voltage drop.
Most important, and one of the most common points of voltage drop is at battery terminals, and ground connections to block and head to fire wall. These connections need to be freshly remade before the following tests are performed. Often a ½ volt or more can be scrubbed from the system with these connections.
Voltage drop can be checked by placing one probe of volt meter on negative battery terminal, and the other on case or frame of voltage regulator, alternator, and spark controller if you have electronic ignition. The optimal reading is zero, 0.1 -0.2V is max drop allowed with ignition key on. The fix for this would be to run a ground loop of #12 gage conductor to one all three devices mounting screws, and back to battery negative terminal. To test under dash make up a jumper that connects to neg. battery post long enough to reach the dash area. This will insure a good ground with no drop to work from.
Next test the voltage difference between negative battery terminal, and all connections of charging circuit as above, but second probe to be landed on each brass connection in that circuit with engine running. This includes ignition switch connections, both sides of bulkhead connector for big brown, big red, and big black wire, as well. Anything that adds up to 0.2v difference is unacceptable and needs to be repaired with new connections, or carefully cleaned to remove excess resistance in the circuit.
So what I’m saying hypothetically is, as you test from battery to engine side of bulkhead connector finding 0.1 volt drop, than the dash side of bulk head connector same wire find an additional 0.2v drop, at ignition switch in and out 0.1v drop, and back out through the connector finding 0.2 drop, those drops are added giving 0.6v drop; too much it is ½ volt high. These tests have to be made at each of the connections in the charging circuit including voltage regulator, ballast resistor, field wire etc. Performing connection to connection readings show where a problem exists, readings between battery and the far end of charging circuit will show total drop, but not which points it is coming from.
A half volt of drop read by voltage regulator will cause alternator to increase voltage by one half volt.
I performed the mad bypass after repairing any voltage drop problems, and used the treaded stud on starter rely as voltage sensing point which allowed the charging voltage to become normal. Before this conversion, and voltage drop elimination, my charge voltage was 15.5 volts, which would boil the battery during a long trip.
This testing and repair takes a lot of time, but having electrical system working properly, and reliable is priceless.
