I’d like to see the oem ammeter on a test bench pushed to failure.
I guess the real danger though is the bulkhead connector, and the fact it was designed to handle the 30amp alternator, in its prime..Even bypassed, I would still feel nervous about pushing over 3x what the factory wiring was built for, 50yrs later
You don't even have to push "3x" through some of them depending on the year. A great example is the one right on the MAD site:
............and I've seen SEVERAL of those more than a dozen perhaps, and I'm not even a pro mechanic. "Up here" many used to put driving lights, winches, and snow plows on Ramchargers and Dodge trucks.
But even WITHOUT THAT the ammeter failure mode is typically this:
1.....Some years the cluster housing/ mounting for the ammeter is made of soft plastic.....you warm it up, it gets soft and loose. The ammeter studs go through that and depend on it to remain "tight."
2.....The ammeter studs where they hook to the internal shunt/ "guts" of the ammeter are NOT welded/ brazed/ soldered. They depend, simply, on the pressure of the mounting nuts, see (1) above
3....Even without the plastic housing in (1), the ammeter must have fiber insulating washers, and if anything is loose enough to heat, and enough current WILL heat it, then the washers deform, soften, loosen, cook, crack, etc etc AND THE CONNECTIONS come loose
One website I've come across advocates soldering the studs to the shunt.....but you STILL have to have the nuts tight on the wiring
4.....Last, and this happened to me........the wire ring terminals themselves can fail on the end of the wires, causing..........heat......and ........failure.
I damaged an ammeter in my 70RR back in the 70's and I had no where near "3x" the amperage through the ammeter
Here is one article on ammeter damage and repair:
Bullet-Proof Your Ammeter (A 'How To') - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Heated/ corroded/ damaged ammeter studs
Cleaned up and soldered
Having said all this, I LIKED ammeters, but rather than put up with what I've run into in the past, I'll gladly eliminate the darn thing.
Your other choice is to engineer yourself an external shunt ammeter like the later vehicles used, along with Ferd and GeeMsee
