Alternator Amp test
Electrical and Ignition
  1. Darren
    Darren FABO Gold Member FABO Gold Member
    1,429
    568
    Mar 1, 2006
    ontario
    Local Time:
    1:21 AM
    Hey guys
    I'm doing some work on my 68 barracuda.
    It's a 383 S matching #. I have upgraded to MP electronic ignition and cracked back's headlight relay kit (that I still have to install) I want to leave the original amp meter (good idea ?) I bought a sunpro volt meter that I was going to convert and install in place of the amp meter in cluster but changed my mind.
    Any way my question is..
    Is there a way to test my current alternator to confirm the amp rating?
    Can a alternator repair shop spin it up?
    I want to leave the car as close to original as possible but want it to be safe..
    The car has original radio.
    Thanks for any advice.
    • Like Like x 1
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      58,977
      46179
      Jan 18, 2006
      Iowa
      Local Time:
      1:21 AM
      You need a tester with a inductive amp clamp. (pickup) They are available as a accessory for a quality DVOM (digital volt/ohm meter) or as a stand alone meter like this.
    • 65wgn440
      65wgn440 Well-Known Member
      321
      157
      Aug 16, 2016
      Toledo, ohio
      Local Time:
      2:21 AM
      Also, yes any alternator repair shop can check amperage output. And if you do keep stock amp gauge, make sure your bulkhead connector is in A1 shape.
    • Darren
      1,429
      568
      Mar 1, 2006
      ontario
      Local Time:
      1:21 AM
      So I assume you clamp around the alt output wire?
      Is there a specific RPM or time (first start up in morning) to do this test?
      Sorry for my electrical ignorance..
      Thanks.
    • Darren
      1,429
      568
      Mar 1, 2006
      ontario
      Local Time:
      1:21 AM
      Yes I actually bought a new bulkhead connector and will be going through it ..
      Thanks
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      48,832
      17004
      Oct 14, 2010
      Idaho
      Local Time:
      11:21 PM
      Well there's more to it than clamping on an ammeter. You need a way to load the battery, the "go to" device back in the day was known as a "carbon pile" load tester. This is an instrument, often containing both a large value ammeter and voltmeter, and an adjustable carbon resistor, huge, 1 each, with a huge knob up front. You can simulate various loads at will as well as test starter draw, and determine battery condition.
      Test procedures are laid out in the service manuals, and you can download many years from MyMopar....free
      I don't recommend this brand--or not--just a photo for reference
      • Agree Agree x 1
      • halifaxhops
        halifaxhops It's going to get stupid around here! FABO Gold Member
        66,506
        36352
        Jan 20, 2014
        Hoppyworld
        Local Time:
        2:21 AM
        As above a carbon pie tester is the ony way to draw max amps SAFELY
        • Agree Agree x 1
        • mderoy340
          mderoy340 Well-Known Member
          2,433
          1216
          Aug 2, 2012
          Melbourne FL
          Local Time:
          2:21 AM
          If the car is running just turn on the high beams, fan, ac compressor, etc and see what the output is at 2k rpm.
        • halifaxhops
          66,506
          36352
          Jan 20, 2014
          Hoppyworld
          Local Time:
          2:21 AM
          That will just match the load, not full output.
        • mderoy340
          2,433
          1216
          Aug 2, 2012
          Melbourne FL
          Local Time:
          2:21 AM
          True but it will give the OP an idea of wether or not the alt is operating correctly without taking anything apart.
        • 67Dart273
          48,832
          17004
          Oct 14, 2010
          Idaho
          Local Time:
          11:21 PM
          Sorry it really doesn't. The headlights and such don't draw all that much in comparison to typical modern day alternators of 50-60 and more output. Many can do that much with a couple open diodes, even though this generates a lot of ripple. It WILL give you a "quick and dirty" idea that the thing is charging somewhat, and that is about all
        • toolmanmike
          58,977
          46179
          Jan 18, 2006
          Iowa
          Local Time:
          1:21 AM
          That is a carbon pile battery load tester and voltage meter. It has a amp meter for testing battery load but no way to test alternator amperage output. It just measures alternator voltage output.
        • 67Dart273
          48,832
          17004
          Oct 14, 2010
          Idaho
          Local Time:
          11:21 PM
          Of course you can use it to test an alternator. You simply use the device to create a battery load. You have to be able to load the system otherwise on a "big" alternator you may have system voltage "to the moon"
          This is the start of the alternator output test from the 1972 Plymouth service manual. Please notice the bottom line.........
        • halifaxhops
          66,506
          36352
          Jan 20, 2014
          Hoppyworld
          Local Time:
          2:21 AM
        • Tooljunkie
          Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
          18,673
          19886
          Jul 22, 2017
          Manitoba
          Local Time:
          1:21 AM
          Loading an alternator unnecessarily without the proper equipment is a good way to release the magic smoke.
          Have at it.
          I have used the carbon pile test, but i dont go too far. Its not worth the risk.
          In order to load it, you have to pull those amps through the bulkhead connector and ammeter. And all that questionable wiring.
          • Agree Agree x 1
          • Darren
            1,429
            568
            Mar 1, 2006
            ontario
            Local Time:
            1:21 AM
            Hi guys thanks for all the info.. I don't mind pulling the alt and having it tested if that's still a option..
            Thanks.
          • halifaxhops
            66,506
            36352
            Jan 20, 2014
            Hoppyworld
            Local Time:
            2:21 AM
            Local parts store should be able to do it. Ask them what it is putting out they might just say "it's good" Napa is usually more informed on the older parts IMO.
          • Darren
            1,429
            568
            Mar 1, 2006
            ontario
            Local Time:
            1:21 AM
            A old friend of mine works at a local alt/starter repair shop.. maybe he can help..
            Thanks again
          • halifaxhops
            66,506
            36352
            Jan 20, 2014
            Hoppyworld
            Local Time:
            2:21 AM
            Perfect!
            • Agree Agree x 2
            • Mattax
              Mattax Just the facts, ma'am FABO Gold Member
              12,193
              7938
              Feb 7, 2013
              Phila. Pa
              Local Time:
              2:21 AM
              Before you go to the parts store, identify the alternator.
              See if its the original, or possibly the original for the engine.
              Then copy the pages from the shop manual showing the service test.
              This is the only reference I know of relating the 'rating' to an actual performance test.
              If your friend's shop has more specific bench test reference, great. But I wouldn't count on it.
              • Like Like x 1
              • Agree Agree x 1
              • my68barracuda
                my68barracuda Well-Known Member
                1,764
                1486
                Dec 6, 2009
                Indianapolis IN
                Local Time:
                2:21 AM
                The AutoZone store near me does free alternator testing. After the test they provide a print out that shows max alternator output among other items.
                • Like Like x 1
                • Tooljunkie
                  18,673
                  19886
                  Jul 22, 2017
                  Manitoba
                  Local Time:
                  1:21 AM
                  Best place to take it.
                • 67Dart273
                  48,832
                  17004
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  11:21 PM
                  Really? Then what is the risk of driving it that way (as we actually used to do) and burning up the stuff you just mentioned in "normal operation." That is the exact purpose of testing.............to find the shit and get it out of there If the bulkhead connector/ ammeter won't put up with a very short term load test, then maybe they are the problem........which they are..........
                • 67Dart273
                  48,832
                  17004
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  11:21 PM
                  Some store / bench testers are "ok" and some aren't. The BEST way to test a charging system is "in the car" in which it is being used........as I mentioned earlier.......the "sections", the components, the output circuit, and the field circuit. Testing in-car can test the entire system as a whole.
                  Most bench testers don't have the horsepower to fully load a high output alternator. It takes a LOT of power to spin a say, 100a alternator up to full shaft output RPM
                  • Thanks! Thanks! x 1
                  • my68barracuda
                    1,764
                    1486
                    Dec 6, 2009
                    Indianapolis IN
                    Local Time:
                    2:21 AM
                    Remember the qu
                    Remember the only question the OP had was ‘what is the amp out put of his alternator’. He was not asking about a complete check of the cars electrical system.
                    • Agree Agree x 1
