SRT_DSTRHOLC
"There is never enough horsepower...."
Hello,
Looking at the alternator mounting on a 6.4 Gen3 hemi. I was able to bolt in one of the 3(?) bolts. The one I have in is from the Top side (pass fender well) and the other (2) look like they come in from the frame rail side. However there is less than an inch of spacing. I do have the frame marked as the flange lip is too close for liking, but other than that it clears.
The main issue is getting this locked down and getting the hardware in and out. Does anyone have any experience with this? I am not sure if running one bolt is the smartest, as I am not willing to try to do it. The only idea I have come up with is notching the frame with a small C notch and then this will allow clearance to insert and remove the bolts, but that's work I would like to avoid.
