Alternator not charging
Electrical and Ignition
  1. partsman1965
    partsman1965 Well-Known Member
    447
    46
    Jul 16, 2013
    Bourbonnais, Illinois
    Local Time:
    2:31 AM
    Looking for help! My 74 Dart sat all winter indoors and when started for first time this spring
    alt charged for short bit then stopped. I have done the following.
    New Alternator since old one was making noise anyway
    New regulator
    New ballast..4pin
    New ground battery cable
    Refreshed all grounds to body and engine.
    I have the wiring diagram and have found no bad wires yet! I have not yet checked wires as they go through firewall. Anyone know which wires through firewall allow alt to charge?
    Main power feed from amp gauge has good connection through firewall.
    • Like Like x 1
    • j par
      j par Well-hung Member
      25,432
      13478
      Jul 2, 2014
      Portland Oregon
      Local Time:
      12:31 AM
      Do you have a free Harbor Freight voltmeter?
    • j par
      25,432
      13478
      Jul 2, 2014
      Portland Oregon
      Local Time:
      12:31 AM
      And I hope you bought the regulator that was a couple dollars more and not the really cheap one cuz that could be your problem right there. But again we need to start with the cheap Harbor Freight voltmeter. Or any voltmeter for that matter.
    • j par
      25,432
      13478
      Jul 2, 2014
      Portland Oregon
      Local Time:
      12:31 AM
      High School auto shop A1A just because you bought a new part does not mean it works.
      (RIP Mr. Kingham)
    • partsman1965
      447
      46
      Jul 16, 2013
      Local Time:
      2:31 AM
      I got a Standard brand regulator. I also have a good Craftsman voltmeter.
    • j par
      25,432
      13478
      Jul 2, 2014
      Portland Oregon
      Local Time:
      12:31 AM
      So in this situation I put the voltmeter on and check the volts from the battery. I continue right there checking the volts and have the wife crank it over and start it and notice how much it drops while cranking? Then of course what it's doing while it's running? Did it go up did it go down did it stay where it was at?
    • j par
      25,432
      13478
      Jul 2, 2014
      Portland Oregon
      Local Time:
      12:31 AM
      Sometimes you'll see it bouncing up and down and that's the regulator opening and closing.
    • partsman1965
      447
      46
      Jul 16, 2013
      Local Time:
      2:31 AM
      Thank you!
    • Mattax
      Mattax Just the facts, ma'am FABO Gold Member
      11,175
      7070
      Feb 7, 2013
      Phila. Pa
      Local Time:
      3:31 AM
      Read this so you have a good idea how the circuit works.
      Understanding Charging Systems with Ammeter
      On yours, the blue wire feeds the alternator's field and the green wire controls the connection to ground completing the circuit. So the blue will connect with voltsage regulator and the ignition 'run' side junction on the ballast resistor. This is how the regulator knows the system voltage. It regulates by opening and closing the circuit's connection to ground.
      • Agree Agree x 1
      • Mattax
        11,175
        7070
        Feb 7, 2013
        Phila. Pa
        Local Time:
        3:31 AM
        Field is another name for the electomagnet that spins. The windings create an magnetic field when powered up.
        Here's a general diagram of the later charging systems like yours.
        • Agree Agree x 1
        • AJ/FormS
          AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
          19,422
          7252
          Jan 19, 2014
          South-Central Manitoba,Canada, 900ftelevation
          Local Time:
          2:31 AM
          You can prove your alternator CAN work by full-fielding it. You run a jumper from the battery plus to the field terminal, and then ground the second terminal. You will connect the ground, with the engine running, the battery recently charged and a VOLTmeter previously installed across the battery, and all accessories turned off..Alt output must be higher than battery rest voltage by at least 1.25 volts, and increases with rpm. Do not go crazy with rpm, you might blow the ignition module. If it makes the minimum, consider it to be ok.
          I connect the ground last while watching the voltmeter, and as soon as I see the voltage, I disconnect the ground. In this way I prevent damage to sensitive components. The charge circuit itself will happily work at 15.5 volts, and mine has withstood 17 volts on occasion. But the headlights didn't.
        • 67Dart273
          67Dart273 FABO Gold Member FABO Gold Member
          45,624
          13355
          Oct 14, 2010
          Idaho
          Local Time:
          12:31 AM
          Post 11!!^^
          But in addition, test for an open from battery to alternator output
          Hook up as above, and with the jumper connections made, slowly bring up RPM and see if battery voltage rises
          If not, move your meter to the alternator "big stud" (output stud) and see if that voltage rises and if so, to a high level. If it does, then you have a bad connection in the circuit from output to battery
          If neither meter connection shows a rise, attempt to determine if the field is actually drawing current. With the engine off, and "in the shade" preferably darker, hook/ unhook your connections to the field. You should be able to see a small spark every time you connect the jumper.
        • partsman1965
          447
          46
          Jul 16, 2013
          Local Time:
          2:31 AM
          Found it! Black ammeter lead at firewall was not making good connection!
        • Mattax
          11,175
          7070
          Feb 7, 2013
          Phila. Pa
          Local Time:
          3:31 AM
          Black ammeter lead goes to the firewall?? Typically red goes to firewall bulkhead; black goes to main junction. Alternator output is generally Black 12 gage and goes from firewall to main splice.
          Each year is a little different so that's why I say generally. You may be right.
        • AJ/FormS
          19,422
          7252
          Jan 19, 2014
          Local Time:
          2:31 AM
          That location is often the root of charging issues, and the fat red one in there as well.
        • 73beast
          73beast Active Member
          36
          6
          Feb 25, 2012
          albany OR
          Local Time:
          12:31 AM
          Found this thread on a search, and thanks for the info!
          Solved my charging issue, had a bad connection at the firewall bulkhead connector. Mines a black wire from the alt to the bulkhead, was a cooked/corroded connection.
          Will bypass when I find a decent passthrough connector, just cleaned it up for now
          • Thanks! Thanks! x 1
          • Mattax
            11,175
            7070
            Feb 7, 2013
            Phila. Pa
            Local Time:
            3:31 AM
            Depending on your goals, one option is to use no connector. Put a ring terminal on the alternator stud, run a heavy black wire through a grommet in the firewall. If done in parallel to the original wire it can be attached with a ring terminal to the alternator side stud of the ammeter. Otherwise splice into the original alternator feed to the main splice as long as its a very good splice.
          • Kendog 170
            Kendog 170 Let the boy go !
            1,425
            922
            Mar 10, 2016
            Tewksbury Ma.
            Local Time:
            3:31 AM
            Some remove the wire from bulkhead connector and drill right thru with drill bit that makes a snug fit. Then as said feed wire through and add your ring terminals.
